The example in the file(src/user_examples/cs_user_performance_tuning.c.) you mentioned helps me to force CSR for scalar matrices but not for the velocity(version 4.0). But if I want to set MSR for the velocity and CSR for most scalar matrices, what should I do?
Best Regards,
Jackie
Using both MSR and CSR Matrix
Re: Using both MSR and CSR Matrix
The setting is done for a specific fill type. So you need to force the MSR format for the CS_MATRIX_BLOCK_D fill type in addition to forcing CSR for CS_MATRIX_SCALAR and possibly CS_MATRIX_SCALAR_SYM.
If I set the file(src/user_examples/cs_user_performance_tuning.c.) you mentioned, most linear systems should use CSR. But recently I find that most linear systems still use NATIVE when I use callgrind tool for the call graph. It shows that "_mat_vec_p_l_native" is the main call for CG, and _b_mat_vec_p_l_native is the main call for block_3_jacobi.
but If set the MSR format for the CS_MATRIX_BLOCK_D fill type. It shows that "_mat_vec_p_l_native" is the main call for CG, and _b_mat_vec_p_l_msr is the main call for block_3_jacobi.
No matter how I set the file, I still get the similar result. I don't know why this keeps happening? And I don't know how to set the two matrix format for the same time, there is no user example for me.
The revise code as follow:
(1)CSR format
(2)MSR format
Best Regards,
Jackie
(1)CSR format
cs_matrix_variant_t *mv
= cs_matrix_variant_create(CS_MATRIX_CSR,
cs_glob_mesh->i_face_numbering);
cs_matrix_variant_set_func(mv,
cs_glob_mesh->i_face_numbering,
CS_MATRIX_SCALAR,
2,
"default");
cs_matrix_set_variant(CS_MATRIX_SCALAR, mv);
cs_matrix_variant_destroy(&mv);Code: Select all
CS_MATRIX_33_BLOCK_D,
2,
"default");
cs_matrix_set_variant(CS_MATRIX_33_BLOCK_D, mv);
cs_matrix_variant_destroy(&mv);Best Regards,
Jackie
At the beginning of your block (2), for MSR, you still have CSR instead of MSR. Fixing the typo should help.
Thanks a lot. That's a mistake. But when I fix the error, I still get the same problem.
Best Regards,
Jackie
Best Regards,
Jackie
Which solvers are you using for which variables ? Could you follow the forum's usage recommendations regarding details to provide ?
