simulation with cs_fan : missing fans_ids field
sirlb
Post by sirlb »
In CS 4.3.0, i am trying to set up a case with a fan.
I have only added the cs_user_parameter-fan.c file in SRC and then run the case.
The computation fails with the following message :
cs_field.c:2127: Fatal error.
Field "fans_ids" is not defined.
   1: 0x7fc782f23103 <cs_field_by_name+0x63>          (libsaturne.so.0)
   2: 0x7fc782f20391 <cs_fan_flag_cells+0x171>        (libsaturne.so.0)
   3: 0x7fc782f20589 <cs_fan_compute_flows+0x89>      (libsaturne.so.0)
   4: 0x7fc782fe59a2 <predvv_+0x5922>                 (libsaturne.so.0)
   5: 0x7fc782fd23fb <navstv_+0x2276>                 (libsaturne.so.0)
   6: 0x7fc783003619 <tridim_+0x4d79>                 (libsaturne.so.0)
   7: 0x7fc782ec82e5 <caltri_+0x2a55>                 (libsaturne.so.0)
   8: 0x7fc782e99ada <cs_run+0x48a>                   (libsaturne.so.0)
   9: 0x7fc782e9950f <main+0x12f>                     (libsaturne.so.0)
  10: 0x7fc7807c6af5 <__libc_start_main+0xf5>         (libc.so.6)
  11: 0x4008f9     <>                               (cs_solver)
I understood that cs_fan_flag_cells function is calling cs_field_by_name with "fans_ids" name for the field but this one is not existing.
I tried to see in which part of the code this field could be initialized but didn't find so far.
Any ideas ? Is there another parameter file in which we have to declare fans and initialize fields ?
Thanks,
sirlb
Re: simulation with cs_fan : missing fans_ids field
Post by sirlb »
For information, I reconfigure my case for version 4.2.1 and simulation is running.
This seems to be a problem with version 4.3.0.
Has anybody observed the same behaviour ? or do i have a corrupted installation ?
There seems to be a bug due to some renaming. We'll fix this in 4.3.1, but in the meantime you may edit src/base/cs_fan.c and replace cs_field_by_name("fans_ids") with cs_field_by_name("fan_id") where you find it.
sirlb
Post by sirlb »
Yes this is working pretty well. Thanks for the fix.
I also notice a strange behaviour between 4.2.1 and 4.3.0 :
In 4.2.1, my fan model does not log any volume for my fan (adding extra code to report cell count show 0 cell in the fan). But computation results show that the fan is properly working and flow field seems ok.
In 4.3.0, the same model log the actual fan volume.
I don"t really understand why, but i guess i will switch back to 4.3.0 with your fix, so everything should be ok.
Best regards.
sirlb
Post by sirlb »
oh wrong info, this is not related to 4.2.1/4.3.0 because i also have wrong logging info in 4.3.0.
this must be caused by the code i've changed; but this is very curious since i didn't modified any of the lines dealing with fan cell flag or volume computation.
I seem to recall having added an or modified options for the postprocessing of fan placement visualization between 4.2 and 4.3 (would need to check git or the ChangeLog for details), so the difference is probably ony due to additional postprocessing/verification output; and so is probably related to this new "feature".
sirlb
Post by sirlb »
I still don"t understand why sometime the logging is correct and sometimes not. (both in v4.2.1 and v4.3.0.
I am interested in postprocessing the fan cells selection. For now I am stuck with 4.2.1 (v4.3.0 gives me full of NaN during computation for same settings).
My guess is that i have to use the function cs_fan_cells_select of cs_fan.c to create a mesh in cs_user_postprocess.c.
Is that correct ? Would you have any exemple available ?
You solution (using cs_fan_cells_select in cs_user_postprocess.c) should work, but requires a bit more work than the buil-in visualization, which should work.
If you have a small, non-confidential case which produces NaNs under version 4.3 but works under 4.2, could you post it here so we can debug it ?
