Export mesh
andrea28
Export mesh
Post by andrea28 »
In Salome, is it possible to export the mesh from a .case file?
Thank you,
Andrea
Re: Export mesh
What do you call a .case file ?
andrea28
Re: Export mesh
Post by andrea28 »
A file like the one produced by CS in the RESU directory.
Re: Export mesh
Those are output files in the EnSight Gold format.
SALOME's PARAVIS can read those files, but if you want to export a mesh to a format readable by the SMESH module, you need to change the output format to MED.
andrea28
Re: Export mesh
Post by andrea28 »
Thanks for the help.
I am using Syrthes now and when I try to convert the mesh:
convert2syrthes4 -dim 3 -m shroud_mesh.unv -o mesh.syr
I get:
convert2syrthes : convert mesh file to SYRTHES format
SYRTHES file opened : mesh.syr
Ideas universal file opened : shroud_mesh.unv
Ideas mesh file : wrong type of elements found (type=44)
The mesh works properly on CS, plus is very simple (file attached).
mesh.rar
(3.72 MiB) Downloaded 1334 times
Re: Export mesh
Do not forget that Syrthes only handles triangles and tetrahedra. To split quads and hexahedra into triangles, you need to do that under SALOME.
andrea28
Re: Export mesh
Post by andrea28 »
Thanks that was the issue.
Pisolino
Re: Export mesh
Post by Pisolino »
Hi all,
i'm facing a similar problem with a .unv mesh made only by tet elements.
SYRTHES file opened : Mesh_2.syr
Ideas universal file opened : Mesh_2.unv
Ideas mesh file : wrong type of elements found (type=41)
For what i googled 41 should be triangular elements, is there something wrong? my syrthes version is automatically compiled from ubuntu 18.04 repository, should i just compile a personal version?
thanks
Andrea
Andrea
mail: info@argosrl.eu
site: www.argosrl.eu
Re: Export mesh
Looking at the unv reader in the Code_Saturne sources, I confirm type 41 seems to be for linear triangles, and even checking in the Syrthes sources, type 41 seems to be handled/read (along with type 91) so this is quite strange.
Installing your own version might indeed be a safe bet...
