pressure inlet / subroutines
koch
Post by koch »
I tried hard to find solution for inlet imposed pressure boundary condition. I understand that the only solution is to use subroutines. There is a topic http://code-saturne.org/forum/viewtopic.php?f=9&t=627 where the solution is shown.
When I paste this to my cs_user_boundary_conditions.f90 file, I got an error:
raise RunCaseError('Compile or link error.')
cs_case_domain.RunCaseError: Compile or link error.
I verified log file and there were two types of errors:
- Error: Invalid form of array reference at (1)
- Error: Symbol ‘iel’ at (1) has no IMPLICIT type
I attach log file.
First I found that there was a mistake in subroutine - rcdocl -> rcodcl but it was no difference in output.
I thought that maybe it is a problem with fortran, but I tried to run with empty boundary conditions subroutine, solver started but I got another error:
In listing I got:
(out of 19)
has boundary condition type 32764, center (1.63787e-316, 6.9396e-310, 6.9396e-310)
cs_boundary_conditions.c:640: Fatal error.
I got crazy about that. I don't know how to start with subroutines and with this inlet pressure. Can anybody help me?
I use Code_Saturne 4.0.5
Maciek
compile.log
(2.03 KiB) Downloaded 395 times
Re: pressure inlet / subroutines
You example is from a very old version, and the syntax has changed. You mostly need to remove the (iphas) references, which have been removed. If iel is not defined, you need to define a local integer variable named iel. Did you check the user boundary condition examples from the code documentation (http://code-saturne.org/doxygen/src/cs_ ... mples.html) ?
