I use Code_Saturne 3.0.0 for my trainee placement to examine flows in a mixer and I began with the bright tutorials available on this site.
I build my mesh with SALOME 6.6.0 exactly as it's explain in the tutorial called "how to set a study in SALOME". I don't use CFDSTUDY modul but it changes nothing, steps to configure Code_Saturne stay the same.
Calculations work well, and I use Paraview 3.12.0 for postprocess. When I open the *.case, I can have all my results at each time step in sheets, and they seen to be correct, but I don't succeed in show the animation or the screen at each time step. There is just the screen of the last step when the flow is steady, and animation tools change nothing...
Can you help me please ?
My mesh and the configuration in Code_Saturne are exactly the same as in the tutorial (i can't join .med) : http://code-saturne.org/cms/documentation/Tutorials
Problem for postprocess with Paraview 3.12.0
Re: Problem for postprocess with Paraview 3.12.0
How is this related to the theme of this forum ?
Usage would seem more adapted...
In any case, ParaView 3.12 is a very old version. I don't know if the issue is a ParaView bug or a usage issue, but I don't have such an old version available to test.bIn addition, if you have polyhedra in your mesh (often the case if you have mesh joining), any version of ParaView older than 3.14 will have issues reading the files...
