SYRTHES 4.3 with CS 3.0.7
andrea28
Post by andrea28 »
I have Code Saturne 3.0.7 installed on Red Hat Linux, which version of Syrthes do you suggest to install?
Thanks for the attention
Andrea
Re: SYRTHES 4.3 with CS 3.0.7
If I remember correctly, a change in the coupling protocol was done between CS 3 and 4, leading to the Syrthes 4.2/4.2 differences (i.e. Syrthes 4.2 and 4.2 were almost identical, with Syrthes 4.2 compatible with Code_Saturne 3.0, and Syrthes 4.2 compatible with Code_Saturne 4.x...
So Syrthes 4.2 would be the recommended version.
andrea28
Post by andrea28 »
Thanks!!!
andrea28
Post by andrea28 »
Sorry, do you know where i can find this version? because on the Syrthes site I get only version 4.3 and 4.1.1 .
Thank you.
Sorry, I throught there was an "official" public version 4.2. As this seems not to be the case, for Code_Saturne version 3.0, you can use Syrthes 4.1.1 instead (version 4.2 will not be compatible)
andrea28
Post by andrea28 »
thanks for the reply, I am having this error during the installation: ple_config.h: No such file or directory.
Do you have any suggestion? I have attached the setup file and the error file.
Andrea
ERREUR.log
(588 Bytes) Downloaded 1183 times
setup.ini
(4.36 KiB) Downloaded 1234 times
Your path to libple in the setup.ini seems to be the path to the ple directory in the Code_Saturne sources, but the path you need is the one of the Code_Saturne install..
andrea28
Post by andrea28 »
Thanks for the help,
I finally install Syrthes without errors, but now when I try to source it I get
SYRTHES4_HOME=...path to the architecture... Command not found.
NOM_ARCH=... Command not found.
LD_LIBRARY_PATH= ... Command not found.
SYRTHES4_MPIPATH= ... Command not found.
SYRTHES4_HOME: Undefined variable.
Thanks for the attention.
Which command do you use to source it ?
andrea28
Post by andrea28 »
I used both
source ../bin/syrthes.profile
Andrea
