Boussinesq approximation
GautierR
Post by GautierR »
I'm trying to implement the Boussinesq approximation as define in the Heated Cavity Square tutorial. I've tried to start from the reference file with the 'example 1: variable density as a function of temperature'.
As I a real beginner with Fortan subroutine, I've first try to implement it with the GUI user define law, but I don't really know how I can get the fluid properties with this tool. (like viscosity or thermal conductivity)
Then I've tried to write it in the 'usphyv' subroutine. But I get lost with all the notation. Some of the function or variable are not explained in the user guide (but I may be wrong). I put in attachment the property fortran subroutine and the compile.log.
Moreover if you have any advice/general method concerning implementation of subroutine, I think it could be really useful.
Thank you in advance,
Gautier
Edit : I have finally a version without any error in compilation, but the calculation stop at the first iterate.
I use the windows version 4.0.
listing.txt
(24.44 KiB) Downloaded 448 times
compile.log
(9.67 KiB) Downloaded 437 times
cs_user_physical_properties.f90
(16.16 KiB) Downloaded 443 times
Re: Boussinesq approximation
Another user posted a similar question recently, so you may first try the forum for "bousinesq". I don't guarantee this will be enough, but it should help you see what the general options are, and get you started.
Ruonan
Post by Ruonan »
I just want to note that for the heated square tutorial case, the cs_user_physical_properties.f90 subroutine in this post worked well. I use version 7.0 and got good results. Thank you!
Ruonan
