Run an existing case
gdib
Post by gdib »
Hello, I found this example very interested and I want it to run it on my PC using code_saturne 3.3 and Linux.
" Matthieu Guillaud
Post subject: Inner flow in a piston
This case consists in stuying a fluid flow inside a piston with a sudden expansion.
____________________
piston.xml [7.5 KiB]
pistonfinal.unv [3.1 MiB] "
I create a file where I downloaded both attachments and then I open GUI from the terminal ( $code_saturne gui). And from the GUI I selected the " piston.xml " but it didn't work.
Can someone help me ?
Thanks a lot
Re: Run an existing case
Could you provide more details on what you tried and how it failed (error messages) ?
Also, version 3.3 is not maintained anymore, so I recommend either version 4.0 (stable) or 4.2 (dev snapshot).
