Axail fan modelling usin cs_fan.h
jb_l
Post by jb_l »
I'm trying to modelize an axial fan using the cs_fan.h.
Looking at the doxygen documentation in the programmer's documentation, things seem to have change since http://code-saturne.org/forum/viewtopic ... =axial+fan
As far as I've understood things :
In cs_user_initialization.f90, I've to define and initialze the fan.
In cs_user_source_terms, I've to tell to CS to compute the added source terms with tsvvtl.
For the moment, i've added those lines ine cs_user_initialization-fan.f90 in the SRC directory of the case, after the [init] :
 ! Fan initialization
call cs_fan_define(1, 3, (/ 0., 0., 0. /), (/ 0., 0., 0.2 /), .707d0, .65d0, .1d0, (/ 300., -14.67, 0. /), 1.d0)
! 1 : constant_f
! 3 : fan dimension 3 : 3D
! cu : intersection coords. of axis and inlet face
! cd : intersection coords. of axis and outlet face
! .707d0 : fan radius
! .65d0 : blades radius
! .1d0 : hub radius
! fcar : curve coefficients, dgre 0,1 and 2 of the characteristic curve
! 1.d0 : fan axial torque
!call inivtl()
! call numvtl(fannbr)
! print *, fannbr
When trying to run a calculation, I get the followings in the compile.log :
cygwin warning:
  MS-DOS style path detected: C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90
  Preferred POSIX equivalent is: /cygdrive/c/tmp/TestCodeSaturne/Fan/fan1/RESU/20160222-1829/src_saturne/cs_user_initialization-fan.f90
  CYGWIN environment variable option "nodosfilewarning" turns off this warning.
  Consult the user's guide for more details about POSIX paths:
    http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90:48.5:
   dt     )
     1
Warning: Unused dummy argument 'dt' at (1)
C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90:92.28:
integer          iel, iutile
                            1
Warning: Unused variable 'iutile' declared at (1)
C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90:47.17:
 ( nvar   , nscal  ,                                              &
                 1
Warning: Unused dummy argument 'nscal' at (1)
C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90:47.7:
 ( nvar   , nscal  ,                                              &
       1
Warning: Unused dummy argument 'nvar' at (1)
cygwin warning:
  MS-DOS style path detected: C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\cs_solver.exe
  Preferred POSIX equivalent is: /cygdrive/c/tmp/TestCodeSaturne/Fan/fan1/RESU/20160222-1829/cs_solver.exe
cs_user_initialization-fan.o:cs_user_initialization-fan.f90:(.text+0x15f): undefined reference to `cs_fan_define_'
collect2: error: ld returned 1 exit status
"C:\Program Files (x86)\Code_Saturne\4.0\bin\x86_64-w64-mingw32-gfortran" -I C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne -I "C:\Program Files (x86)\Code_Saturne\4.0\include\code_saturne" -x f95-cpp-input -Wall -pedantic-errors -std=f2003 -O -c C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\src_saturne\cs_user_initialization-fan.f90
"C:\Program Files (x86)\Code_Saturne\4.0\bin\x86_64-w64-mingw32-g++" -o C:\tmp\TestCodeSaturne\Fan\fan1\RESU\20160222-1829\cs_solver.exe cs_user_initialization-fan.o "-LC:\Program Files (x86)\Code_Saturne\4.0\lib" -L/home/MFEE/opt/x86_64-w64-mingw32/lib -L/home/MFEE/opt/x86_64-w64-mingw32/lib -L/home/MFEE/opt/x86_64-w64-mingw32/lib -L/home/MFEE/opt/x86_64-w64-mingw32/lib -L/home/MFEE/opt/MPI/lib -L/home/MFEE/opt/x86_64-w64-mingw32/lib -O -Wl,--allow-multiple-definition -lsaturne -lple -lcgns -lmedC -lhdf5 -lscotch -lmsmpi -lxml2 -lz -lz -L/usr/lib/gcc/x86_64-w64-mingw32/4.8.2 -L/usr/lib/gcc/x86_64-w64-mingw32/4.8.2/../../../../x86_64-w64-mingw32/lib/../lib -L/usr/x86_64-w64-mingw32/sys-root/mingw/lib/../lib -L/usr/lib/gcc/x86_64-w64-mingw32/4.8.2/../../../../x86_64-w64-mingw32/lib -L/usr/x86_64-w64-mingw32/sys-root/mingw/lib -lz -lgfortran -lmingw32 -lmoldname -lmingwex -lmsvcrt -lquadmath -ladvapi32 -lshell32 -luser32 -lkernel32 -lm
Does anybody know what could be wrong?
As you may have found, I'm running on Windows 7 64 bits
Code_saturne version is 4.0.2
Thanks a lot for your help...
JB
Re: Axail fan modelling usin cs_fan.h
Actually, you need to call fans from C code (cs_user_parameters.c instead of cs_user_parameters.f90).
Unfortunately, I don't believe fans work well in 4.0: they were an update of an old, unfinished development, which was not much used, and not part of the validation suite. The fan functionality has seen new use and testing very recently, and is in a mostly working state starting with version 4.2, with some fixes in the branches but not yet in releases (so you would need to add cs_fan.c from the trunk: http://code-saturne.org/viewvc/saturne/ ... iew=markup, as the fix has not been merged to branch 4.2 yet; i'll try to remember to merge it tomorrow).
In any case, I would not recommend using this with any version older than 4.2...
Note that the theory documentation for fan is not available yet: I have an old, partial documentation from an older code in which that functionnality existed, but we need to translate it from French ton English and from a pdf to LaTeX or Doxygen...
jb_l
Post by jb_l »
thanks a lot for your answer, Yvan.
As I run code_saturne on Windows, is there any recompilation to do, or I just have to replace the cs_fan.c file in the installation directory by the one found in the trunk?
By the way, do you know if it is possible to have two Code_saturne installation in parallel on windows? A 4.0.3 and a 4.2? Or is it better to have only one? In this case, I'll have to update my install.
Jb
Adding the cs_fan.c from the head of the 4.2 branch to your SRC directory (assuming you switch to version 4.2) should work.
Installing 2 Code_Saturne versions in parallel works well on Linux, and should probably work on Windows (though I need to check with Cyril on that), but I am not sure it has been tested.
jb_l
Post by jb_l »
I've tried to copy cs_fan.h, cs_fan.c and cs_user_parameters-fan.c from a CS 4.2.1 installation on Linux in the SRC directory of a case build with CS 4.0.3 on Windows.
The compilation fails. This way to do doesn't seems to be very clean.
So, in order to overcome this issue, I've try to modelize a simple case of an internal fan with CS 4.2.1 on Linux.
The mesh was built in Salome.
The domaine is a box of 0.5 m side length
The mesh is an hexaedral one, with cell size of 0.02m in every direction.
External faces of the domaine have been grouped in a "Wall" face group.
I've then set my case in CS, using stationnary simulation and air as fluid.
I've copy cs_user_parameter-fan.c in the SRC directory, and changing the fan setting as follow :
cs_user_parameters(void)
   * We define a fan, which will be handled as an automatic
   * explicit source term. See cs_fan_define() prototype
   * or Doxygen documentation for details.
  /*! [fan_user_1] */
    const cs_real_t  inlet_axis_coords[3] = {0.22, 0.25, 0.25};
    const cs_real_t  outlet_axis_coords[3] = {0.28, 0.25, 0.25};
    const cs_real_t  fan_radius = 0.05;
    const cs_real_t  blades_radius = 0.02;
    const cs_real_t  hub_radius = 0.02;
    const cs_real_t  pressure_curve_coeffs[3] = {0.6, -0.1, -0.05};
    const cs_real_t  axial_torque = 0.001;
    cs_fan_define(3, /* fan (mesh) dimension */
                  inlet_axis_coords,
                  outlet_axis_coords,
                  fan_radius,
                  blades_radius,
                  hub_radius,
                  pressure_curve_coeffs,
                  axial_torque);
  /*! [fan_user_1] */
Then, I ran the simulation.
There is no compiling error and simulation run.
But when checking the listing file, it appears that there is no fluid motion in the domain.
Velocity stay at 0! :o
What did I do wrong in my set up?
Please find enclosed the listing file.
JB
listing.txt
(73.55 KiB) Downloaded 983 times
jb_l
Post by jb_l »
With a reread of the code of cs_user_parameter-fan.c posted above, I've seen the following mistakes :
Blade radius = 0.02 and hub radius = 0.02 too.
So, there is no flow for a fan without blade....
Damnely true...
Moreover, the pressure curve coeffs aren't very phisical for my case.
So, I've changed them to something found for an electronic cooling fan of 92mm diameter.
The cs_user_parameter-fan.c is now :
  /*! [fan_user_1] */
    const cs_real_t  blades_radius = 0.048;
    const cs_real_t  pressure_curve_coeffs[3] = {40.88, -1474.7, 4587.1};
                  inlet_axis_coords,
                  outlet_axis_coords,
                  fan_radius,
                  blades_radius,
                  hub_radius,
                  axial_torque);
  /*! [fan_user_1] */
The subroutines compile and the calculation run until the end, but the listing file is very strange.
From iteration 3, it's look like diverging :
INSTANT    0.300000000E-01   TIME STEP NUMBER               3
   ** BOUNDARY MASS FLOW INFORMATION
Boundary type          Code    Nb faces           Mass flow
Inlet                     2           0         0.000000000E+00
Smooth wall               5        3750         0.000000000E+00
Rough wall                6           0         0.000000000E+00
Symmetry                  4           0         0.000000000E+00
Free outlet               3           0         0.000000000E+00
Free inlet               13           0         0.000000000E+00
Convective inlet         15           0         0.000000000E+00
Free surface             14           0         0.000000000E+00
Undefined                 1           0         0.000000000E+00
   ** BOUNDARY CONDITIONS FOR SMOOTH WALLS
                                         Minimum     Maximum
   Rel velocity at the wall uiptn :  0.00000E+00 0.00000E+00
   Friction velocity        uet   :  0.00000E+00 0.00000E+00
   Friction velocity        uk    :  0.10000E+13-0.10000E+13
   Dimensionless distance   yplus :  0.10000E+13-0.10000E+13
   Nb of reversal of the velocity at the wall   :          0
   Nb of faces within the viscous sub-layer     :       3750
   Total number of wall faces                   :       3750
@ @@ WARNING: MESH TOO REFINED AT THE WALL
@    The mesh seems to be too refined at the wall to use
@      a high-Reynolds turbulence model.
@    The last time step at which too small values for the
@      dimensionless distance to the wall (yplus) have been
@      observed is the time step          3
@    The minimum value for yplus must be greater than the
@      limit value YPLULI =    0.23810E+01
@    Have a look at the distribution of yplus at the wall
@      (with EnSight or ParaView for example) to conclude on
@      the way the results quality might be affected.
@    This warning is only printed at the first two
@      occurences of the problem and at the last time step
@      of the calculation. The vanishing of the message does
@      not necessarily mean the vanishing of the problem.
   ** INFORMATION ON CONVERGENCE
   Variable    Rhs norm      N_iter  Norm. residual      Drift  Time residual
c  Velocity             NaN       1   0.00000E+00           NaN         NaN
c  Velocity[X]                                              NaN
c  Velocity[Y]                                              NaN
c  Velocity[Z]                                              NaN
c  Pressure             NaN       0   0.00000E+00           NaN 0.00000E+00
c  k                    NaN       1   0.00000E+00           NaN         NaN
c  epsilon              NaN       1   0.00000E+00           NaN         NaN
  ** "Clippings" des champs calculés
   champ                min. init.      max. init.   lim. à min.   lim. à max.
a  k
a  epsilon
a  Local Time Step
  ** Champs calculés sur cellules
   champ                   minimum         maximum   moy. ensemble   moy. spatiale
v  Velocity[X]                 inf            -inf            -nan            -nan
v  Velocity[Y]                 inf            -inf            -nan            -nan
v  Velocity[Z]                 inf            -inf            -nan            -nan
v  ǁVelocityǁ                  inf            -inf            -nan            -nan
v  Pressure                      0               0               0               0
v  k                           inf            -inf            -nan            -nan
v  epsilon                     inf            -inf            -nan            -nan
v  TurbVisc                    inf            -inf            -nan            -nan
v  CourantNb                   inf            -inf            -nan            -nan
v  FourierNb                   inf            -inf            -nan            -nan
v  total_pressure       1.0132e+05      1.0132e+05      1.0132e+05      1.0132e+05
v  Local Time Step       0.0098945         0.01331        0.013308        0.013308
  ** Champs calculés sur faces de bord
v  Yplus             inf            -inf            -nan            -nan
  ** Valeurs calculées sur cellules
   criterion               minimum         maximum   moy. ensemble   moy. spatiale
   Courant/Fourier             inf            -inf            -nan            -nan
Fans
    id      surface       volume         flow       deltaP
     0   4.0800e-02   8.0000e-05         -nan        -nan
Does anybody know what is wrong?
Please find enclosed the full listing
JB
listing.txt
(2 MiB) Downloaded 984 times
The code actually seems to diverge from iteration 1...
Could you try running on a single rank (i.e. non-parallel) for an iteration or 2 ? I don't expect this will change anything, but it is a quick check, so I recommend doing it "just in case".
Also, do you have access to or can you install a debug build ? A debug build is slower, but should catch the divergence (or division by zero, ...) much closer to the cause of the error, making it much easier to analyze and fix.
Finally, increasing verbosity to 2 for all variables (search for "iwarni" in the user subroutine examples) will also help pinpoint where the problem originates.
jb_l
Post by jb_l »
Unfortunately, I don't have access to a debug build.
The solution would be to install another instance of CS with debug option on my Linux install.
Why not, but as it's quite complicated for me to properly install CS, I would like to explore other options before.
I've tried the same case using serial solver.
This doesn't seem to change anything.
I've also put IWARNI variables to 2 and relaunch the simulation.
Here is the listing file of the run.
Something is strange to me : why there is only 1 iteration for velocity, k and epsilon?
Also, the maximum number of iteration seems to have been removed from the GUI.
Where can I found it in order to check that the value is correct?
If you found something interesting in the listing, please let me know!
Thanks a lot.
JB
listing.txt
(478.01 KiB) Downloaded 975 times
The number of iterations might be limited by the fact the solver detects an divergence immediately, so stops there (you have a "nan" right away for the velocity).
Did you check the same computation without fan modeling ? I assume the error is due to the fan model, but it is safe to check anyways...
A debug build would be useful here, but otherwise, adding src/base_cs_fan.c to your user sources, could you add checks than elements are indeed selected for fans ?
In the "trunk" version (4.3 which will be released this summer), we added a visualisation of selected fan zones, but version 4.2 does not have this feature...
jb_l
Post by jb_l »
I've run the simulation without fan modeling.
There is no problem. (it's a pure internal fan in a cube, so here, I have a cube with wall BC on every faces and without any speed or moment in...). K and epsilon seems to converge correctly.
How can I add checks for selected cells for fan?
I'm really poor in C coding...
Thanks a lot
JB
