I was successful with my first study and I want to show here what I did. Perhaps somebody could review this and give me some hints about what is wrong and what is ok.
The study is about stratification of water in a storage tank. I hav made a geometry in salome that include a pipe that goes horizontally into a storage tank. The geometry is attached here. The pipe has a diameter of 100mm. I have built only the part of the tank I thought would be important. Only half of the geometry is actually built and I use the symmetry boundary condition in code saturne. The water in the tank has a temperature of 40°C. The water coming through the pipe is at 60°C. I want to see how the warm water flows into the tank.
The geometry is meshed with the mesh module of salome. The mesh is tetrahedral without viscous layer and has around 194000 cells. A view of a part of the mesh is also attached here.
Now to code saturne: I use version 4.4.1 debian package.
The mesh check says about mesh quality:
Number of bad cells detected: 41 --> 0 %
I checked steady flow. The turbulence model is Rij-epsilon SSG. I first tried with k-epsilon Linear Production but had errors in the listing telling me that the mesh was too fine. I don't know a lot about the different turbulence models and took the tip from one of the best practice guides. I don't know if this model is the right one but I didn't get errors.
I have no radiative transfers and no conjugate heat transfer (perectly insulated tank).
For the Fluid properties I took the equations for water from a tutorial.
The boundary conditions are:
- Inlet where the water comes in with a speed of 0.03m/s and 60°C Temperature
- Wall with standard settings
- Outlet with standard settings that I don't understand (prescribed flux = 0)
I have set the timestep to 0.5 seconds. A complete calculation run with 400 steps takes around one hour what is statisfying to me with a Intel I5 processor with four cores.
Postprocessing is done with paravis showing the temperature in the symmetry plane, see attached.
The result looks reasonable to me although I cannot really judge it as I'm not a fluid physics specialist. So if somebody could give me some info about what is wrong or right or what could be done better this would help me a lot.
Very best regards
Elektrix
