[*]I am currently trying to write a converter fro GridPro format to MED, using the Python API.
I managed writing node and cell information, using
mesh.setCoords(coordsArr)
for the nodes and
mesh.insertNextCell(mc.NORM_HEXA8, 8, conn)
for the cells
This is reasonably well documented in
http://docs.salome-platform.org/latest/ ... mples.html
However, now it comes to the boundary conditions, things get rather obscure.
It seems I need to create a 'family' of my boundary cells specified to be 'ON-FACE'. I understand the principles, but the way to do this using the Python API is not clear.
Does somebody have an example for a simple case how to do this, for example for a box grid as used in the
shear driven cavity case?
Thanks in advance !
specifying boundary condition in MED file using Python API
Re: specifying boundary condition in MED file using Python A
I am not familiar with the MEDCoupling Python API (I am more familiar with the MED C API).
If your geometry is relatively simple, you could import it under SALOME, and use geometric filters to select mesh boundary faces on which to apply/define groups (saved internally as families, which are basically "group classes").
For something more automatic regarding SALOME scripting, you have better chances on the SALOME forum at salome-platform.org (you may also specify that for Code_Saturne, you need face/element families, not node families).
martin.spel@rtech.fr
Hello Yvan thanks for your quick reply to my post. I finally found out how to set the BCs:
First extrude the surface mesh fro the volume mesh
surfaceMesh,desc,descIndx,revDesc,revDescIndx=volumeMesh.buildDescendingConnectivity()
Next, identify the cell ids in this surface mesh and store them in a vector (faceIds)
Finally create a MedFile with the two meshes
mm = ml.MEDFileUMesh()
mm.setMeshes([volumeMesh, surfaceMesh])
and set the groups that reference the identified cells
group=ml.DataArrayInt(faceIds)
group.setName(self.bcMappings[bcMap])
# add to the list of groups
groups.append(group)
mm.setGroupsAtLevel(-1, groups)
This seems to work well, but I'lI have to do some further testing on complex meshed before making available the converter
