HELP!!!!!
Re: HELP!!!!!
You mean no folders are created at all ? Can you try again, or tell me what folders are created ?
zanelatoeb
Re: HELP!!!!!
Post by zanelatoeb »
Dears,
I've found the same problem. I'm using Linux Ubuntu 18.04 LTS x64 version.
Using the "code_saturne gui" in Linux Terminal (version 5.0.1), when I click on "file" and "new file", the DATA directory is automatically loaded as "associated sub-directories of the case". However, the folders "RESU", "SRC" and "SCRIPTS" don't.
How can I solve this?
Thanks a lot,
Erick.
Re: HELP!!!!!
If you have not already created a case structure, use "create new case" instead of "create new file".
I know this could be made more clear and be improved, but would require quite a few subtle changes in the scripts and case structure, so for now, this should do.
