HELP!!!!!
giannitu
HELP!!!!!
Post by giannitu »
I've tried a small mesh for a wind simulation in SAlome and then i've exported in Code Saturne, and I've followed a Tutorial to adjust all the parameters, but it doesn't works: when I push the Batch analysis button doesn't appens anything.
May it depends from a bad use of Code Aster or is there something that doesn't goes in the window installation of the software?
Is there the opportunity to download a tutorial complete of the files to check directly on my pc?
Thank in advance!!
Gianni
giannitu
Re: HELP!!!!!
Post by giannitu »
Please help me!!
I can't understand what is appening!!
Re: HELP!!!!!
Please provide more details, as recommended in the forum guidelines. The less info you provide, the harder it is to help you.
Did you try running the case from a terminal ? (running the SCRIPTS/runcase directly).
Pablo
Re: HELP!!!!!
Post by Pablo »
Although more information will be desirable, because many reasons could explain your error, sometimes a strange CS behavior such as what you mention happens if the CASE folder is placed in a "long" path. In this situation the simulation is not launched, without any information in the console/listing file etc, neither with an error nor any clue at all.
Try to move the case folder (all files contained in the /STUDY folder) to a shorter path (such as /Desktop/STU00/CASE00/...) and re-launch the simulation, at least, the output windows information listing shall be launched.
I hope it works, good luck
Re: HELP!!!!!
Hello Pablo,
Do you observe this behavior in a systematic manner with a long path ? this bug seems intermittent, and shows up more on some installs then others, making it hard to track down, but if you have a recipe which always provokes the bug, this will make it much easier to reproduce and fix, so I am interested by any comment you may have here.
giannitu
Re: HELP!!!!!
Post by giannitu »
thanks to everybody for the answer.
First of all I apologize for the lack of information, but I'm new of the forum and I've to improve.
You will find attached the whole directory of the simple study that I've done to try the software, before starting a complex study, please give a look!!!
I've placed the main directory (called CFD) in C:, so there are no long-name path.
Thanks again for your help!!!
P2.rar
(8.27 MiB) Downloaded 689 times
Re: HELP!!!!!
For this type of issue, info on your system (OS version) is probably more important than the contents of the directory. So what system are you running on ?
Also, do you have any accents in your path ? they might cause issues (or at least this is somewhat untested).
Finally, I did not find any "runcase" script in your SCRIPTS file. Did you create the study structure using "New case" in the GUI's file menu or "code_saturne create" in a terminal (which should be equivalent), or did you just build directories manually to match the structure described in the documentation ? There should be a file named "runcase" (or "runcase.bat" under Windows) in the SCRIPTS directory, which does not seem to be present in your case structure.
giannitu
Re: HELP!!!!!
Post by giannitu »
Thanks!!
I use Windows...
Now I've created the new study using "New Case" and now it works, but I need to understand the right use of the software...
Please, if I can find a complete case to install and run on my Pc it will be wonderful.
Thanks a lot.
Gianni
Re: HELP!!!!!
The documentation is weak / too hard to find in this regard, but basically, if you place files from the tutorial examples (in the "examples" subdirectory) in the "correct" subdirectories of a study or directory generated with the GUI (source files in SRC, xml in DATA, meshes in a MESH directory just above the case directory), you should be all set.
kennethchaw
Re: HELP!!!!!
Post by kennethchaw »
Hi, I think i also faced the same problem. I created the case using the function in GUI, but the folders are not created, so I created them myself in Windows. The runcase.bat is not generated in SCRIP folder.
Please help. I am trying out from one of the tutorial.
Thanks.
