"Three 2D disks" coupled case ran only one iteration.
Posted: Sun Apr 26, 2015 6:34 am
by ffan
Dear Code_Saturne users and developers,
I tried the example case “Three 2D disks” following the instruction http://code-saturne.org/cms/sites/defau ... -disks.pdf
The fluid and the solid parts, separately, ran without a problem. However, the coupled case ran only one iteration before stopping. (The model is attached here.) Why did it run only one iteration? Thank you very much.
- ffan
Re: "Three 2D disks" coupled case ran only one iteration.
Posted: Sun Apr 26, 2015 1:39 pm
I am not sure, but as it seems (accoring to your logs) that Syrthes is requesting the stop, you should try removing the syrthes.stop file in the Syrthes (solid) setup directory.
Posted: Mon Apr 27, 2015 8:07 am
by ffan
Yvan,
Thanks.
- ffan
