Dear Code_Saturne users and developers,
I tried the example case “Three 2D disks” following the instruction http://code-saturne.org/cms/sites/defau ... -disks.pdf
The fluid and the solid parts, separately, ran without a problem. However, the coupled case ran only one iteration before stopping. (The model is attached here.) Why did it run only one iteration? Thank you very much.
- ffan
"Three 2D disks" coupled case ran only one iteration.
- 3disks2D.tar.gz
- (4.79 MiB) Downloaded 770 times
Re: "Three 2D disks" coupled case ran only one iteration.
I am not sure, but as it seems (accoring to your logs) that Syrthes is requesting the stop, you should try removing the syrthes.stop file in the Syrthes (solid) setup directory.
Yvan,
Thanks.
- ffan
Thanks.
- ffan
