Hello.
Could somebody provide me with an example of usage of mathematical expression editor to fill in momentum sources (Su, dSudu, etc.)? It seems I don't understand correctly the methode and receive sustematic error in running the solver. Sorry for this first silly question...
Thanks in advance, regards, PhJ.
GUI - Momentum source - Math. expression editor
Erwan Le Coupanec
Re: GUI - Momentum source - Math. expression editor
The momentum source terms you can fill in the GUI are then used as follows:
|\Omega_I|)
where
: volumic production of momentum - explicit part (
: volumic production of momentum - implicit part (
As a first attempt, you can put the whole source term in the explicit part
Erwan.
where
Erwan.
Phjod
Hello.
I appreciate your help.
I understand theory and concept, but all what I try to implement in the GUI - math editor - even simplest things as constant everywhere on al 6 parameters, results in solver failure with SIGSEGV... That is the reason why I ask for an example, trying therefore to locate my mistake by doing this. Initialisation is no problem, just moment source definition
Ph.
Ph.
Could you post files as per the forum recommendations to let us understand what type of error you obtain ?
