CS 4.0b - Output control strange behavior
Pablo
Post by Pablo »
Hello everyone:
I am on the first stages of the CS-4.0b testing and I have realized of an strage behaviour on the results output control for steady-state simulations: No matter how do I change the output control frequency, (either by "n" steps or true-time scale), it is always saved as one result per second in the result file.
I have checked the generated "xml" file and the paragraph seems to be right, so, for example:
<analysis_control>
<output>
<listing_printing_frequency>10</listing_printing_frequency>
<mesh id="-1" label="Fluid domain" type="cells">
<all_variables status="on"/>
<location>all[]</location>
<writer id="-1"/>
</mesh>
<mesh id="-2" label="Boundary" type="boundary_faces">
<writer id="-1"/>
</mesh>
<probe_format choice="DAT"/>
<probe_recording_frequency>1</probe_recording_frequency>
<writer id="-1" label="results">
<directory name="postprocessing"/>
<format name="ensight" options="binary"/>
<frequency period="time_step">5</frequency>
<output_at_end status="on"/>
<time_dependency choice="fixed_mesh"/>
</writer>
</output>
<profiles/>
<steady_management status="on">
<iterations>10</iterations>
<relaxation_coefficient>0.7</relaxation_coefficient>
<zero_iteration status="off"/>
</steady_management>
<time_averages/>
<time_parameters>
<iterations>200</iterations>
<max_courant_num>1</max_courant_num>
<max_fourier_num>10</max_fourier_num>
<property label="CourantNb" name="courant_number"/>
<property label="FourierNb" name="fourier_number"/>
<property label="LocalTime" name="local_time_step"/>
<time_passing>2</time_passing>
<time_step_max_factor>1000</time_step_max_factor>
<time_step_min_factor>0.1</time_step_min_factor>
<time_step_ref>0.05</time_step_ref>
<time_step_var>0.1</time_step_var>
<zero_time_step status="off"/>
</time_parameters>
</analysis_control>
...as it is defined a steady-state simulation with 200 iterations of 0.05 seconds/iteration ("total time" 10 seconds), and having defined an output control of the results of a record every 5 iterations, it would be expected to have 40 results records (one result every 0.05 seconds), but there is only 10 result records in the result file.
No matter if I change the output control recording to every 0.05 second per output register, the result file recording do not change: one per "physical" time.
Where could the mistake be? :?
EDIT:
It also happens for transient-simulations.
RTEST00.XML
(6.94 KiB) Downloaded 366 times
Re: CS 4.0b - Output control strange behavior
This is strange; I just ran a similar test on my side, and did not encounter this issue (I ran 40 steps for a steady calculation, output every 5 time steps, and obtained 8 output records).
Could you also post your listing file, as it has a summary of writer parameters. ?
Pablo
Post by Pablo »
Ok, I have re-run a similar steady-state simulation than yours so that:
- 80 iterations
- 0,1 secs/it
- Writer output every 5 iterations (expected 40 results)
...and I have achieved 8 results for 8 seconds of simulation :?
Attached XML, log file and mesh files attached
2,5DMESH.tar.gz
(497.82 KiB) Downloaded 386 times
listing.txt
(97.47 KiB) Downloaded 355 times
RTEST00.XML
(6.67 KiB) Downloaded 389 times
Do you still have the issue with 200 time steps ? (maybe the problem was due to some partial update) ? If it still fails, could you post the listing for the case that fails ?
Pablo
Post by Pablo »
Hello:
I attach a case which fails: the XML and the listing file generated.
According to the simulation definition:
Steady-state simulation:
·····Constant time-step= 400 iterations
·····Reference time step= 0.05 s
Output control:
·····Log frecuency: Every "n" time-steps= 20
····Writer Frecuency: Every "n" time-steps= 10
According to what I suppose (and I've confirmed in previous simulations in previous CS releases), this configuration should simulate 20 "seconds" of result behaviour with one log every 20 time-steps in the listing and 40 states to represent (1 result every 0.25 seconds) in the result file, but there only are 20 states in the result file ( 1 every second ).
I hope this information helps.
Thank you, as always.
RTEST00.XML
(6.64 KiB) Downloaded 405 times
listing.txt
(241.89 KiB) Downloaded 383 times
Im am not able to reproduce your bug: I built an xml file based on yours, on a simple cavity, adapting only the boundary conditions to my mesh, and obtained 40 time steps, not 20...
Do you have any user subroutines ?
Pablo
Post by Pablo »
Sorry for the delay, but I have been busy these days.
I have not any subroutine loaded at all, it is just a smple simulation generated as I realize that something failed with the pulverized coal combustion tutorial in CS4.0b.
This issue happens to me in my personal laptop (Xubuntu 14.0.4, with the 3.3 Saturne pre-requisites updated at July 2014), which, prior erasing of the previous release of CS, I installed the CS4.0b.
Anyway, and I do not know how, I have installed the CS-4.0b in the office's workstation (as I have re-installed the SO Xubuntu 14.0.4 and all the saturne pre-requisites updated at today) and now the simulations behaves as usual, without any trouble with the results recording in the result file. (even with the coal-combustion tutorial, as far as I have checked by now)
The only difference between both machines is the pre-requisites versions, so I am going to compare them and re-install CS4.0b in my personal laptop in order to check if something is not working as it should.
I will keep you informed.
Kind regards,
Hello Pablo,
I'll probably be uploading a new 4.0 beta later today, with some fixes relative to combustion, so you may want to wait a bit before reinstalling...
Pablo
Post by Pablo »
Well, although a little late, this problem was caused by the post-processing program (Paraview). Its reinstalling fixes the problem.
