Dear All,
I'm using Code_saturne version 3.2 and it seems that the enthaply initialisation doesn't work with this version. I couldn't define in some region an other enthalpy(temperature) than the defined temperature. It seems also that the user defined files (cs_user_boundary_condition and cs_user_parameters ...) are not really taking into account.
Please, is any solution?
Enthalpy initialisation with code_saturne 3.2
Re: Enthalpy initialisation with code_saturne 3.2
If you dont' post at least your user subroutines and xml file, it will be hard to check what is wrong.
Christophe Loubet
I am just reporting a bug for someone who want to use the electric arc module with the CS Version 3.2. I am going back to CS Version 3.0 and electric arc simulations run well.
Sincerely.
Sincerely.
In any case, they will need to provide details to fix the issue for 3.2. Or better, wait a few days for a first 4.0 beta and test directly on that version...
