I may have miss it in the documentation but i am wondering if it is possible to make a run only to compute some additionnal information using cs_user_postprocess_var.f90.
In my mind, there will be no need to make additional iteration, just reading the restart files and compute the new fields with the subroutine.
Is it possible ?
make a run for only post-processing
Re: make a run for only post-processing
You should be able to do this by setting the numbers of iterations to the current value +1 iteration. CS will then run for one more iteration and also compute and output the information you want in the user routine.
Brian Angel.
Brian Angel.
