how to output the temperature on the boundary?
chengan.wang
Post by chengan.wang »
Hello everyone
I have a small question here:
Now I'm working on the coupled problem between natural convection and radiation. I want to use the temperature in the domain and on the boundary. Here, I try to ouput the temperature on the hot wall, on which the temperature is constant. But the result got by the following code is variable.(The cordinates are correct)
open(21,file="chaud.dat")
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
iel = ifabor(ifac) ! associated boundary cell
write(21,*)cdgfbo(1,ifac),cdgfbo(3,ifac),rtpa(iel,ivar)
enddo
close(21)
I guess I couldn't use "rtpa(iel,ivar)" to get teh temperature on the boundary face. If somebody knows how to deal with it?
Thank you!
(10.91 KiB) Downloaded 79 times
Jacques Fontaine
Re: how to output the temperature on the boundary?
Post by Jacques Fontaine »
There is an example (true if there is no wall function) in usproj (v2.2):
! Compute reconstructed value in boundary cells
    compute grad T with grdcell -> gradT
    do ifac = 1, nfabor (loop on boundary faces)
      iel = ifabor(ifac)  (boundary faces -> cell connectivity)
      diipbx = diipb(1,ifac) (compute vector II', cf: theory guide)
      diipby = diipb(2,ifac)
      diipbz = diipb(3,ifac)
      TempIp(ifac) =   rtp(iel,isca(iscalt))              &
                    + diipbx*gradT(iel,1)                   &
                    + diipby*gradT(iel,2)                   &
                    + diipbz*gradT(iel,3)
    enddo
So we have:
Next, you need to reconstruct the value at the face (cf: theory guide (condli)):
iclvar = iclrtp(isca(iscalt), icoef)
  TempF(ifac) = coefa(ifac, iclvar) + coefb(ifac, iclvar)*TempIp(ifac)
enddo
To output the result, it is quite simple in sequential mode, in parallel you have to be prudent and to use synchronization functions (in this case paragv).
chengan.wang
Thank you for your answer.
In fact, I use orthogonal mesh and I have two kinds of boundary conditions, one is Dirichlet, left and right wall, I can use "coefa" directly to get temperature; I apply the Neumann condition on the top and bottom walls, if I can also calculate the temperature the same way you show me?
Sincerely,
Chengan WANG
Jacques Fontaine
If you use orthogonal meshes you can use coefa and coefb directly. Same way for Neuman/Dirichlet BC.
In my previous post please note my edit in the 2nd "Code box" (iclvar added).
chengan.wang
If there is wall function (when I use LES), what should I do for ouput the exact temperature?
Best regardes
Chengan
