I am using Code_Saturne 3.0
In former versions, imposing arbitrary values of ntcabs or ttcabs (for postprocessing outputs) was possible with usnpst.F
Now, as I understand, the function cs_user_postprocess_activate of routine cs_user_postprocess.c seems to handle that.
The problem is that I don't understand the way it works.
For example, if I'd like to activate for ntcabs=145,317 and 982, how would I do ??
Thanks in advance.
postprocessing without subroutine usnpst
Re: postprocessing without subroutine usnpst
The cs_user_postprocess_activate routine should contain an example, which is similar to that of the old routine. ntcabs is replaced by nt_cur_abs, and ttcabs by t_cur_abs (longer versions of the same).
The only additional difference is that you can specify a writer to activate (when using multiple outputs), or activate all. If in doubt, you probably don't need fine grained control, so just activate all writers, using id 0 (ids < 0 are for automatic writers, > 0 for user-defiend writers).
Brian Angel
I see that Yvan has just posted but I've posted this as well. When comparing previous and current versions:
ntcabs = nt_cur_abs = current time step number
ttcabs = t_cur_abs = current physical time
So, in the function cs_user_postprocess_activate you could, for example, code the following:
if (nt_cur_abs == 145)
your C coding here;
Please remember to remove or comment out the "if (false)" statement.
Brian Angel.
your C coding here;
Brian Angel.
Thank you both for your fast and precise answers. Things are clearer to me now.
Best regards.
Best regards.
