ERROR on check mesh and run calculation
b.alladin
Post by b.alladin »
Hello ,
i installed Code saturne but i have this error message when i lunch the check mesh: /usr/local/libexec/code_saturne/cs_solver: error while loading shared libraries: libsaturne.so.0: cannot open shared object file: No such file or directory.
and when i try to run the stury i just have a white empty page .
Re: ERROR on check mesh and run calculation
Did you run "ldconfig" after install, as suggested in the installation guide ?
b.alladin
Post by b.alladin »
hello,
thank you for your answer, i have solved the mesh problem ,but the white page when running case is stilling remaining .
Concernaing the ldconfig, yes i done it.
Thank you sir.
