A quick question - I have been staying clear of the k-omega SST model in code_saturne because I was told that it was 'broken'. Looking into it further the reference for this information is this forum post, which has no replies:
http://code-saturne.org/forum/viewtopic ... wall#p4703
Was this a genuine bug or a case of not setting the model up correctly (eg wrong value on icdpar)? If it was a bug, is it now fixed/gone in version 3? Original post is from June 2011.
Thanks in advance and happy new year!
k-omega SST query
Re: k-omega SST query
I am not sure this was really a bug, in the sense that the behavior switching from smooth to rough wall was non continuous, but changing the model to improve it would require more tests, to make sure we do not degrade other cases. I am not sure who uses k-omega with rough walls, so this has not not been a priority for improvement, but If anyone looks into this closely enough, we will try to follow suit.
A fix relative to very low y+ values (for smooth walls) was implemented in version 3.1, when "scalable wall functions" are not used (not in 3.0 if I am correct).
Otherwise, nothing was changed relative to this model. For finer analysis, the code for the smooth wall is in src/base/clptur.f90, and that for the rough wall in src/base/clptrg.f90.
The parent post seems you link to refer to tests done using the "scalable wall functions" (ideuch=2).
Hello Susan,
We have recently used the k-omega SST model in Code_Saturne and have compared predicted data using this turbulence model with DNS results for a bouyancy driven and a mixed bouyancy-forced convection flow.
For the bouyancy driven flow, the low Reynolds number version of this model correctly predicted the wall heat transfer when compared to the DNS data.
For a mixed natural-forced convection flow, both the high and low Reynolds number versions gave acceptable results when compared to DNS data.
Brian Angel.
Brian Angel.
Thank you both for your replies and the information.
Apologies for the very late response also!
Susan
Susan
