controling rotational velocity of rotating inner mesh
st268
Post by st268 »
Given a rotating meshed disk inside my domain, can I use user_scripts to control the speed of rotation based on what is happening inside my simulation?
thanks
Susan
Brian Angel
Re: controling rotational velocity of rotating inner mesh
Post by Brian Angel »
Hello Susan,
Just to confirm that I've understood your question, you want to control the rotational speed of the disc using, for example, some form of a fluid force i.e. pressure difference or viscous forces acting on the disc, without having to specify a rotational speed.
Brian Angel.
st268
Post by st268 »
Yes that is it exactly. Sorry I was not more clear!
Susan
Jacques Fontaine
Post by Jacques Fontaine »
Hi
You can not do that with cs_user_scripts. Are you using rotor/stator module ?
st268
Post by st268 »
Hi Jacques,
I was planning to yes. But I was hoping there was some way to control the rotational speed based on what is happening during the simulation and not just by giving a fixed value in usini
thanks
Susan
You can do that, but not in user_scripts.py, whic is for the run script. An appropriate user subroutine might be "cs_user_extra_operations", but check the descriptions of the different user subroutines in examples and the documentation to check what is the best fit.
