Hello
How can i introduce heat sources as function of space in a domain? The application is in the process of thermalizing of neutrons in a nuclear reactor.
Thank you
Space dependent heat source
Re: Space dependent heat source
If there is a specific part of the documentation or user subroutines examples for user source terms which is not clear to you, I can try to help, but you need to at least explain what you tried so far and where you are stuck.
