Dear Yvan,
I am not able to define the 'porbes' in my calculations. I have ALE activated for fluid structure interactions. Here is the error message.
System error: File exists
/home/projets/saturne/Code_Saturne/2.2/src/code_saturne-2.2.4/src/base/cs_time_plot.c:637: Fatal error.
Plot number 10 is already defined.
1: 0x2b5636ab6f44 <bft_error+0x94> (libbft.so.0)
2: 0x2b56352a3fc6 <tpsini_+0x286> (libsaturne.so.0)
3: 0x2b563535f07f <strhis_+0x61f> (libsaturne.so.0)
4: 0x2b5635239773 <caltri_+0x5843> (libsaturne.so.0)
5: 0x2b563520da0a <cs_run+0x7da> (libsaturne.so.0)
6: 0x2b563520d213 <main+0x193> (libsaturne.so.0)
7: 0x2b563caa9c4d <__libc_start_main+0xfd> (libc.so.6)
8: 0x401309 <> (cs_solver)
Please find the listing file attached.
I am using Code Saturne V 2.2.4. But problem persists for V 3.0 too.
Thanks in advance for your time.
Vilas SHINDE
EDF Clamart
Number of probes
Re: Number of probes
Could you post your setup so we can reproduce this (if the mesh is too big, we can do without, but we need at least the xml and user subroutines, preferably for version 3.0) ?
First, sorry for late reply.
Please find the param.xml, error, and listing files attached.
FYI, There is no error when I run the calculation without ALE (fluid structure interaction module) selected.
Please let me know if you need further information.
Thanks a ton.
Vilas
Thanks a ton.
Vilas
- error.txt
- (745 Bytes) Downloaded 683 times
- listing.txt
- (44.57 KiB) Downloaded 682 times
- param.xml
- (14.94 KiB) Downloaded 646 times
I do not reproduce the error with Code_Saturne 3.0.1.
Do you have any user subroutines you did not post here ? I don't remember any specific fix betwen 3.0.0 and 3.0-rc1 that would xplain the difference (though I may have forgotten some details).
I am sorry. I did not share user subroutines.
I observe the error without these subroutines with 'param.xml' file attached with this message.
I suspect if it has to do with the activation of structural history output.
Thanks for the concern.
Vilas
Vilas
- error.txt
- (759 Bytes) Downloaded 683 times
- listing.txt
- (44.42 KiB) Downloaded 661 times
- param.xml
- (14.62 KiB) Downloaded 646 times
I just fixed this bug. The fix will be in versions 3.2 (october), 3.1.1, and 3.0.2 (soon).
In the meantime, you can add the attached file to your user subroutines (for version 3.0).
- cs_time_plot.c
- (39.17 KiB) Downloaded 703 times
