cs user source terme
flyer
Post by flyer »
Hello
I ask you for help because I have problems with the new version of saturne CS3 in the applications of ustsns in cs-usersouceterm and the user-boundary. I have adapted the subroutine to this new version, they work in first sight! but after (1000 iteration)get back with my results but without the source term or CB. I noticed that the source term and BC were not taken into consideration even if the calculations are displayed without errors
in Compil.log file it displays Warning: Unused dummy argument 'ckupdc' at (1) smacel (I will send as an attachment) and other error
I then used the default cs-usersouceterm (the ustsns part) in SRC reference and it's the same thing it does not taking account the subroutine
I think, I miss something during installation allowing a saturne to compile correctly, but I do not know what??
compil.log
if you have an idea thank you
compile.log
(3.23 KiB) Downloaded 331 times
Re: cs user source terme
The warning about "dummy arguments" is not a problem.
I don not know what source terms you are trying to define, or what boundary conditions you are using. With version 3.0, be careful with velocity source terms: with the default coupled velocity components (ivelco=1), you must use ustsnv instead of ustsns (both in cs_user_source_terms.f90).
So if you program the wrong function, your source terms will be ignored.
flyer
Post by flyer »
hello
thank you for your response
for term source I used a constant source term S=AU+B A=0 B=cst
crvimp(iel) = 0.d0 crvexp(1,iel)=cst
if (ivar.eq.iu .or. ivar.eq.iv .or. ivar.eq.iw) then
qdm = 100.d0
call getcel('rot', nlelt, lstelt)
do iel = 1, nlet
crvimp(1,1,iel) = 0.0d0
enddo
do iel = 1, nlet
crvexp(1,iel) = 0.5d0*propce(iel,ipcrom)*volume(iel)*qdm
enddo
endif
and the boundary conditions I used a logarithmic velocity profile at the inlet in the same way that the 2.0.5 version that went very well
I used again ustsnv given default and it's the same mistakes in compil.log
if (.true.) return
ckp = 10.d0
qdm = 100.d0
do iel = 1, ncel
crvimp(1,1,iel) = - volume(iel)*propce(iel,ipcrom)*ckp
enddo
do iel = 1, ncel
crvexp(1,iel) = volume(iel)*qdm
enddo
in compil.log i get :
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:117.9:
ckupdc , smacel , &
1
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:116.5:
dt , rtpa , propce , propfa , propfb , &
1
Warning: Unused dummy argument 'dt' at (1)
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:115.9:
icepdc , icetsm , itypsm , &
1
Warning: Unused dummy argument 'icepdc' at (1)
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:115.18:
1
Warning: Unused dummy argument 'icetsm' at (1)
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:115.27:
1
Warning: Unused dummy argument 'itypsm' at (1)
/home/nedjari/ustv/CASE1/RESU/20130429-0940/src_saturne/cs_user_source_terms.f90:113.17:
( nvar , nscal , ncepdp , ncesmp , &
thank you
Guess what :
if (.true.) return
does...
flyer
Post by flyer »
thank's
it's always the same thing even without the if (. true.) return
I send you my subroutine and file compil.log
when installing my cs3, it given an error in cgns instal and it proposed to installed - without-cgns!!! is that it is causing problem ???
thank you very very much
compile.log
(2.92 KiB) Downloaded 304 times
(12.39 KiB) Downloaded 372 times
You are not applying the source term to the correct cells:
You should not have:
call getcel('rotor', nlet, lstelt)
  do iel = 1, nlet
     crvimp(iel) = 0.d0
  enddo
  do iel = 1, nlet
     crvexp(iel) =-0.5d0*propce(iel,ipcrom)*volume(iel)*qdm
  enddo
But:
  do iel = 1, ncel
     crvimp(iel) = 0.d0
  enddo
  do ielt = 1, nlet
    iel = lstelt(ielt)
  enddo
