cs_preprocessor_data.c:206: Erreur fatale.
zeph67
Post by zeph67 »
Hi !
I'm using Code_Saturne 3.0.0. When I run a calculation, the preprocessor step seems to be okay. But finally I get this error :
Aucun fichier ou répertoire "mesh_input" trouvé.
Pile d'appels :
1: 0x7f409cf2a60d <cs_preprocessor_data_read_headers+0x158d> (libsaturne.so.0)
2: 0x7f409ceaecd6 <cs_run+0xd6> (libsaturne.so.0)
3: 0x7f409ceaeb1a <main+0x14a> (libsaturne.so.0)
4: 0x7f409c4fb76d <__libc_start_main+0xed> (libc.so.6)
5: 0x402aa9 <> (cs_solver)
Fin de la pile
... which is surprising, since the mesh is recognized by the preprocessor.
Any idea ?
Thanks in advance.
Re: cs_preprocessor_data.c:206: Erreur fatale.
As per the forum recommendations, could you post a bit more info ? Your xml file possibly cs_user_script.py files, as well as the preprocess.log file would be a start, and passing the output of "ls" in the execution directory would provide more info.
zeph67
Post by zeph67 »
Sorry, I first didn't post them, because I was almost sure that the error encountered, was somehow classical...
No xml file, since I don't use the GUI.
cs_user_scripts.py and preprocessor.log are joint hereafter.
And ls gives the following :
compile.log cs_user_scripts.py error preprocessor.log summary
cs_solver cs_user_scripts.py.txt listing src_saturne
The presence of listing shows that the preproc step was achieved, and the calculation was about to run.
Thanks in advance.
preprocessor.log
(1.36 KiB) Downloaded 663 times
(12.83 KiB) Downloaded 648 times
Did you read the preprocessor.log ? It seems to end prematurely (no "normal end" or error message), so I do not know what happened, but either the end of your posted file is missing, or there was an undetected preprocessing error.
Did you test the same mesh with a previous version of Code_Saturne ?
As your mesh seems to be is very small, could you post it here ?
zeph67
Post by zeph67 »
Yvan, your questions led me to the answer.
Yes, I read the preprocessor.log, and the fact that a "fin normale du préprocesseur" was missing surprised me, but I thought it was a specificity of this new version...
I first used a .msh mesh, that I also converted to .unv format. This latter works (preproc OK, calculation OK).
Thanks a lot for your help.
The .msh mesh should still work, or lead to an error message, so as it seems there may be a bug, we are still interested in your .msh file (either on the forum or by private message or sent to the saturne-support at edf dot fr if it is confidential), so as to check it and debug the code if necessary.
zeph67
Post by zeph67 »
Here it is...
Maybe a bad compilation (I did several months ago)...
Thanks !
canal_1D_Retau_2000_Ny41.msh.txt
(6.23 KiB) Downloaded 657 times
It is a bug: if you replace in preprocessor/pre-post/ecs_pre_gmsh.c, line 502:
ECS_MALLOC(elt_pos_som_ent[ient], nbr_elt, ecs_size_t);
with:
ECS_MALLOC(elt_pos_som_ent[ient], nbr_elt + 1, ecs_size_t);
and recompile, the bug is fixed.
I'll push the fix under version control tomorrow, so the bug will be fixed in bug-fix release 3.0.1 (which we'll probably release within a few days; I'm just waiting for a few minor GUI-related bug fixes.
Thanks for the feedback.
