restart calculation without gui
steph
Post by steph »
Hello
I am using the version 2.0.4. I try to restart calculation without gui.After some modification in isini.1 (ISUITE =1 for example), I launch the calculation, there is a fatal error
/home/saturne/installer/bft-1.1.5/src/bft_file.c:794: Erreur fatale.
Error opening file "suiamo":
No such file or directory
Note that with Gui the restart calculation run without error
If someone could give me some suggestions?
Thanks a lot
Re: restart calculation without gui
You missed the part where you define the path to the restart files in the runcase file.
The GUI would have handled that for you. Did you have any good reason not to use it ? (i.e. did anybody suggest you not to use it ? If that is the case, does that person bother to ensure user support or answer questions on this forum ?).
Also, version 3.0 handles this better (whether using the GUI or not, you only have to set this up in 1 place, not 2).
