code saturne with syrthes
Hakim
Post by Hakim »
Hello everybody,
Is there anyone who can give me the procedure to install code-Saturne and syrthes code, especially code syrthes? The code saturne I have already installed.
Hakim.
Re: code saturne with syrthes
Which versions ?
Hakim
Post by Hakim »
for saturne version 2.0.6 and for syrthes version 4.0.1. Thank for your reply.
regards.
Hakim.
Code_Saturne 2.0 is only compatible with Syrthes 3.4.
Code_Saturne 2.1 and 2.2 may be installed either with Syrthes 3.4 or 4.0
Code_Saturne 2.3 and 3.0 is only compatible with Syrthes 4.0.
The instructions relative build Code_Saturne with Syrthes 3.4 or 2.0 are different, and are described in the Code_Saturne installation manual.
For Syrthes itself, there is a README.txt in the source code, which should be sufficient.
Hakim
Post by Hakim »
Hello yvan;
thank you, I will try to install it
Hakim.
