UNV mesh in Code_Saturne 2.0.0-rc1
Quentin Bey
Post by Quentin Bey »
Hi everyone,
I currently face a problem with an "old" version of Code_Saturne : 2.0.0-rc1. I try to use an UNV mesh but the preprocessor (ECS) fails to load it.
Maybe there is a trick to solve this issue. My UNV file is generated with SALOME (I tried version 5.1.5 and version 6.6.0).
Here is my mesh quality criteria checks :
/opt/saturne/cs-2.0-beta2/bin/cs_preprocess --in ecs_cmd -m
/work/Etude_Box/MESH/box_unvS5.unv --ensight --case check_mesh
  |   Code_Saturne Preprocessor  |
  ECS   version 2.0.0-rc1   (Thu 13 May 2010 05:08:41 PM CEST)
  CGNS 2.5.4 file format support
  MED 2.3.6 (HDF5 1.6.9) file format support
  Reading of compressed files ('.gz') with Zlib 1.2.3.3
Case configuration
  Date                : Wed 06 Mar 2013 02:12:46 PM CET
  System              : Linux 2.6.32-45-generic
  Machine             : samantha
  Processor           : Quad-Core AMD Opteron(tm) Processor 2376
  Memory              : 16468396
  User                : quentin (Quentin BEY)
  Directory           : /work/Etude_Box/CAS_UNV/RESU
  Case name           : check_mesh
  Mesh file           : /work/Etude_Box/MESH/box_unvS5.unv
Reading mesh from file in I-deas universal format
  Mesh file: /work/Etude_Box/MESH/box_unvS5.unv
  Number of vertices                          :        8
SIGSEGV signal (access to forbidden memory area) intercepted !
Call stack
1: 0x42cb0b (cs_preprocess)
2: 0x40e9a8 (cs_preprocess)
3: 0x409f40 (cs_preprocess)
4: 0x7fd14cb18c4d (libc.so.6)
5: 0x4041a9 (cs_preprocess)
Another question : Is it possible to use a more recent preprocessor ? What is the newest preprocessor version that is compatible with CS 2.0.0-rc1 ?
Thanks for any clue or workaround, you may give to me.
Quentin
box_unvS5-UNV.txt
UNV mesh made with SALOME 5.1.5
(3.86 KiB) Downloaded 365 times
Re: UNV mesh in Code_Saturne 2.0.0-rc1
The most recent version of ECS compatible with NCS 2.0-rc1 is ECS 2.0.3 (the latest in the 2.0 branch), which you can download from this web site). An yes, it includes a bug fix relative to UNV files, so it may work better for you.
In any case, I would recommend upgrading at least from 2.0-rc1 to 2.0.6 (3.0-rc1 is better, but will require more changes to your data setup). Version 2.0 will be maintained until version 4.0 is released (december 2014), while 2.0-beta and 2.0-rc versions are not maintained.
Quentin Bey
Thanks a lot for your answer ! My UNV mesh is well read with ECS 2.0.3.
Actually, I'm really interested in an upgrade from 2.0-rc1 to 2.0.6, but I can't find any release note concerning the differences "between those two versions". Are there only minor bug fixes ? I was not able to determine the SVN revisions corresponding so as to watch the logs...
Quentin
For the Kernel, you have an up to date ChangeLog here:
http://code-saturne.org/viewvc/saturne/ ... ersion2_0/
For prerequisites, you would need to download them, to check their ChangeLogs.
For Code_Saturne 3.0, things are both simpler, as there is only one package, and more complex, as the current ChangeLog is autogenerated from subversion logs, and not versioned per se, though the NEWS file is versioned (the NEWS file is now "useful" in both version 2.0 and 3.0 branches, which was not the case even a few weeks ago).
Quentin Bey
Thank you for this answer !
Quentin
