forbidden memory area access
vshinde
Post by vshinde »
Dear code saturne team,
I got below message while running the code (2.0.4 version). I suppose it is linked with the memory access to the code satunre on the my machine. Please guide.
errorfile output
1: 0x42742b <ustsns_+0x68b> (cs_solver)
2: 0x414ffb <preduv_+0x627b> (cs_solver)
3: 0x7f18c9661cb1 <navsto_+0xe01> (libsaturne.so.0)
4: 0x422961 <tridim_+0x9e79> (cs_solver)
5: 0x7f18c94df9a5 <caltri_+0x5085> (libsaturne.so.0)
6: 0x7f18c94baaa3 <cs_run+0x843> (libsaturne.so.0)
7: 0x7f18c94bad85 <main+0x1f5> (libsaturne.so.0)
8: 0x7f18c6a1ac8d <__libc_start_main+0xfd> (libc.so.6)
9: 0x40e989 <> (cs_solver)
Please find the listing file attached.
Thanks in advance for your time.
Vilas
listing.txt
(35.56 KiB) Downloaded 395 times
Re: forbidden memory area access
According to the call stack, the error appears in ustsns, which is a user subroutine.
So you probably have an out-of-bounds error (or missing initialization) in your user subroutine.
In version 2.0, a "favorite" error is to forget resetting iphas to 1 after a loop on iphas, but there are plenty of other possibilities...
So you need to check/debug your code.
guingo
Post by guingo »
as a starting point I would recommend to try in a terminal (in the directory containing your cs_solver)
addr2line 0x42742b -e cs_solver
which can give you the line containing the error (as Yvan said, located in ustsns.f90)
vshinde
Post by vshinde »
Hello, Thank you for the concern.
In user subroutine, ustsns.f90
I read a data from file and then try to store in 'rtuser' array. That is where program stops.
Therefor I believe, it is associated with access to 'rtuser' array from the subroutine. It used to work on some other machine and with other version of code saturne :)
Thanks,
Vilas
