compressible module: ISCALT
alberich
Post by alberich »
I am playing around with the compressible module using the GUI as far as possible, where I chose the option "perfect gas with constant gamma".
When starting the calculation, the solver stops indicating that uscfx2 was not defined. Thus I copied cs_user_parameters.f90 to the /SRC directory only leaving the uscfx2 subroutine. In the uscfx2 subroutine I assigned ivisls(itempk) = 0, visls0(itempk) = 0.15d0, iviscv = 0 and viscv0 = 1.99d-5.
When restarting the calculation, the solver stops stating
@ @@ ATTENTION : ARRET A L'ENTREE DES DONNEES
@ PHYSIQUE PARTICULIERE (COMPRESSIBLE) DEMANDEE
@ La valeur de ISCALT est renseignee automatiquement.
@ L'utilisateur ne doit pas la renseigner, or
@ elle a ete affectee comme suit :
@ ISCALT = 1
@ Le calcul ne sera pas execute.
@ Verifier les parametres.
However, I didn't find any file in the whole project, where ISCALT was set to 1 ...
I tried also to add additionally the subroutine usppmo, in vain.
Any hint where starting to look for the error?
al
Re: compressible module: ISCALT
Could you remind us which version are you using ?
The compressible model works in versions 2.0.x and the latest 3.0-beta, but is broken in intermediate versions 2.1-2.3.
For the compressible model, you must not define a thermal model, whether using the GUI or usipsc. The compressible model defines it automatically.
alberich
Post by alberich »
I'm using version 3.0.0.-betaR4215. A thermal model is not selectable in the GUI when selecting the compressible module. I didn't define one via usipsc either.
al
Could you post your setup (XML file and user subroutines) for us to reproduce/understand/debug this. We don't need your mesh, since the error appears before selecting mesh areas.
alberich
Post by alberich »
I continued playing around and I can't reproduce the error anymore. Since I did delete all the history, I can't post an relevant xml, anymore. I try my best to get again this error.
al
alberich
Post by alberich »
I can now reproduce the error.
If you start a new study from scratch and do a first calculation with Calculation features -> Compressible model = OFF, you can set Thermal model -> Thermal scalar. If you do so and you subsequently change the Calculation features -> Compressible model = Perfect gas with constant gamma, the possibility to set Thermal model -> Thermal scalar disappears. However the calculation stops with said ISCALT error.
When going back to Calculation features -> Compressible model = OFF, then setting Thermal model -> Thermal scalar =No thermal scalar and then switching on the compressible model again, the error disappears.
al
