code saturne with syrthes
Hakim
Re: code saturne with syrthes
Post by Hakim »
I have a problem on Saturne, which I hope you can enlighten me on this. I have a configuration consisting of three domains. The first area is represented by the moving air. The second area is represented by the water which is stagnant. The last area is represented by a solid medium. To couple the solid medium with the fluid medium (air) I have to invoke the code syrthes. But, between the flowing fluid (air) and the fluid at rest (water), both are fluids, how do I proceed. By the way, which version of syrthes is better. Thank you.
Hakim.
For a fluid completely at rest, using Syrthes with the fluid's thermal properties might be possible. Otherwise, You may use Code_Saturne for it (you may deactivate convection for some variables using advanced options if required).
In any case, the simplest setups will be obtained when Code_Saturne domains are coupled only with Syrthes domains (so for example having a solid between 2 fluids is fine, but having the fluids in direct contact make for significantly more compex setups).
Syrthes 4.0 is a big improvement over Syrthes 3.4, but to coupl it with code_Saturne, you will need Code_Saturne 3.0 (also a big improvement over 2.0, though not quite as mature yet).
Hakim
Post by Hakim »
Thank you for your reply, I will try to follow your advice and if I find problems I will let you know
regards,
Hakim.
Hakim
Post by Hakim »
they are some troubles, if you can enlight me.
I installed in my pc code-saturne(3.0) that has not caused me any problems. but when I tried to install it on my laptop, the installation was installed successfully but in execution it is nothing, like I have nothing installed. Can you explain me why?
regards,
Hakim.
You may have different prerequisites installed on both machines.
You need to post the usual files (config.log, ...) at least for the laptop.
Also, did you use the automatic or manual install ?
Hakim
Post by Hakim »
No I removed all previous installations installed and I use automatic installation.
regards,
Hakim.
Hakim
Post by Hakim »
regards,
Hakim
install_saturne.log
(7.46 MiB) Downloaded 675 times
Hakim
Post by Hakim »
i post you the config.log file
regards,
Hakim
config.log
(210.36 KiB) Downloaded 672 times
I did not notice any errors. What happens exactly when you try to run the code on the laptop ?
What command did you try ("code_saturne invo", "code_saturne create", ... ?).
What OS do you have on the laptop compared to the workstation ?
Hakim
Post by Hakim »
after installion, I run code saturne, a message appears on the console: They are no saturne installed you can install it by typing sudo apt-get install-code-saturne-bin. i get that by typing "code_saturne create..."
i have the same operating system( ubuntu 12.04, 64 bits) on both machine.
may be they are some troubles with the server saturne(EDF). Because on the worstation i made the installation almost a month ago.
regards,
Hakim.
