[SOLVED] make check fails
alberich
Post by alberich »
on both versions, the nightly and 3.0.0-betaR4215 (with installer and then manually recompiling), mak check fails with the same message (below).
Any ideas?
al
cs_file_test.c: In function ‘_create_test_data’:
cs_file_test.c:79:20: warning: passing argument 4 of ‘cs_file_open’ from incompatible pointer type [enabled by default]
../src/base/cs_file.h:152:1: note: expected ‘MPI_Info’ but argument is of type ‘MPI_Comm’
cs_file_test.c:79:20: error: too few arguments to function ‘cs_file_open’
../src/base/cs_file.h:152:1: note: declared here
cs_file_test.c: In function ‘main’:
cs_file_test.c:120:25: error: ‘CS_FILE_NO_MPI_IO’ undeclared (first use in this function)
cs_file_test.c:120:25: note: each undeclared identifier is reported only once for each function it appears in
cs_file_test.c:121:25: error: ‘CS_FILE_EXPLICIT_OFFSETS’ undeclared (first use in this function)
cs_file_test.c:122:25: error: ‘CS_FILE_INDIVIDUAL_POINTERS’ undeclared (first use in this function)
cs_file_test.c:189:22: warning: passing argument 4 of ‘cs_file_open’ from incompatible pointer type [enabled by default]
../src/base/cs_file.h:152:1: note: expected ‘MPI_Info’ but argument is of type ‘struct ompi_communicator_t *’
cs_file_test.c:189:22: error: too few arguments to function ‘cs_file_open’
cs_file_test.c:302:22: warning: passing argument 4 of ‘cs_file_open’ from incompatible pointer type [enabled by default]
cs_file_test.c:302:22: error: too few arguments to function ‘cs_file_open’
make[2]: *** [cs_file_test.o] Error 1
[/size]
Re: make check fails
"make check" is not used much (it does not include validation/install checks, but mainly very low-level unit tests, requiring human interpretation), so it might not be fully up to date.
I'll fix it for the next releases, but in the meantime, just ignore that failure.
