My question relates to the post processing Code_Saturne!
How can I access to the velocity values corresponding to each coordinate (x,y,z). In the files of RESU (results) I obtiened just the velocity values corresponding to each iteration time and not the values that corresponds to each cordinate.
thanks for help
code_saturne post processing
stage75
Re: code_saturne post processing
What I want is to convert the file (ch.med.1.11201408 for example or the CutPLanes that resulting from this file) on a file (. Txt) where I can access at the numerical values
The med library includes an mdump utility which allows you to extract convert a MED file to text (not necessarily easily parsable).
Code_Saturne's cs_io_dump utility also allows extracting field values from checkpoint/restart files (the versions from 2.1 on are much more powerful, allowing specific extractions and file comparisons).
stage75
Thank you Yvan,
I can get all the values in each plane using ParaView, but I have more data of velocity that coordinates!!
I think I have this dfifference because the mesh is unstructured???
Data is cell-centered: under ParaView, use the "cell centers" filter first.
