The ICORIO parameter in the usini1.f90 listing can be set =0 or =1.
In a typical 2-stage axial turbine configuration like this, I have built 4 meshes for each blade row with Salome (STATOR1.med, ROTOR1.med, ...)
|/STATOR/|\ROTOR\|/STATOR/|\ROTOR\|
|//////1///////|\\\\\\1\\\\\\|///////2///////|\\\\\\2\\\\\\|
If I want to perform a fully unsteady calculation (IDTVAR = 0, with timestep uniform and constant) do the ICORIOs for ROTOR1 and ROTOR2 have to be set =1 ?
And in a case of steady calculation (IDTVAR = -1) what are the ICORIO settings for the four meshes?
Last but not least, in the ROTOR1 and ROTOR2 domains I need to set the peripherical wall as counter-rotating (because it represents the turbine casing, that is counter-rotating in the relative reference frame respect to a generical observer "sitting on" the rotor). How can I do that?
Thank you very much in advance for the answers
Sir E.
