The Code-saturne is installed. When I run SaturnGUI and click the new_file button, nothing happens. Other buttons or buttons on the menu do not work either. No errer info is reported. Is there an installation mistake?
Nothing happen when clicking New_file button in SaturneGUI
Re: Nothing happen when clicking New_file button in SaturneG
Currently, the GUI only allows you to create new XML files in an existing data structure.
Did you run the GUI in a DATA directory from a case first created using "code_saturne create", or in another directory ?
youngzxlove
Hi, Yvan
Thank you for replying.
Yes, I run the GUI in a DATA directory from a case first created using "code_saturne create", just following the step by step solution in the tutorial. The "close" button, "quit" button do not work either. I have installed v2.0 and v2.3, but the same problem is met. I installed the Saturne without MED and ccmio, but I think this may not lead to such a problem.
Then this does seem to be an installation issue, and MED and/or CCMIO (or any similar library, such a CGNS) are not related.
When you launch the GUI and/or press buttons, do you have any messages in the terminal from which the GUI was run ? If so, could you post them ?
Otherwise, could you provide details on your configuration (config.log, OS version, QT and Python versions) ?
youngzxlove
My OS version is Linux version 2.6.18-128.el5, Python version is 2.7, PyQt version is PyQt-x11-gpl-4.9.5, gcc version is 4.1.2.
This is my config.log file : Thank you
Young
Young
I did not notice anything wrong in your config.log. I did note that you are using gfortran 4.1.2, which is the standard on quite a few older systems, and works up to version 2.3 of Code_Saturne (though it has a bug in debug mode), but will not be sufficient for versions 3.0 and above (because 3.0 starts using Fortran ISO_C_BINDINGS, which are not supported well enough in gfortran 4.1), so for future versions, you will need to install a more recent gcc version. But I digress...
Do you have any error messages in the terminal ?
Also, your bug seems quite similar to one David encountered when working on the Windows port, and which is fixed in 3.0-beta. If I am not mistaken, the matching fix is the following:
edit gui/Base/MainView.py
and replace all "activated" strings by "triggered".
Then re-run "make install" (no need to re-configure), and see if it works (if it does, do tell us, so we'll push this into the 2.0 and 2.3 branches for future corrective versions).
youngzxlove
I replaced activated by triggered, and it works now.
Thank you very much.
Young
Young
Yvan Fournier wrote:Hello,
OK, thanks.
The fix has been pushed in the Subversion repository for all currently maintined versions using PyQt: 2.3, 2.2, and 2.0, and will be available when we next release bugfix versions for those (and is available as of tonight's next mirror syncronization for anyone pulling the code from Subversion).
