Usage of cs_user_mesh_input subroutine
DH07120S
Post by DH07120S »
I want to have the translation of a mesh 5 times in heigh.
In this mesh, there are 4 boundary conditions : bas(down), haut(up), interne and externe.
But if make the translation, I have intermediate boundary conditions which are created.
So I remove the group but I don't succed to remove two groups : haut and bas.
It work for the first mesh and the last mesh because I remove only one group.
But CS create a group : no_group where I remove my groups.
I use the version 2.2.2 of CS.
My code is :
void
cs_user_mesh_input(void)
  /* Add same mesh with transformations */
  if (true) {
    const char *renames[] = {"Inlet", "Injection_2",
                             "haut",NULL};
    const double transf_matrix[3][4] = {{1., 0., 0., 0.},
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.}};
    cs_preprocessor_data_add_file("/home/DH07120S/2754/Etude_Hexa/19_aig_22/MESH/mesh_input/base",2,renames,transf_matrix);
  if (true) {
                             "haut , bas", NULL};
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.180}};
  if (true) {
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.360}};
  if (true) {
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.540}};
  if (true) {
                             "bas", NULL};
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.720}};
Thank you,
Damien
Re: Usage of cs_user_mesh_input subroutine
Some of your renames arrays (the 2nd, 3rd, and 4th ones) seem to contain 5 values, while the should contain an even number of values (old1, new1, old2, new2, ..., with NULL allowed in place of new* for a group to remove).
Could you re-test with corrected renames arrays ?
DH07120S
Post by DH07120S »
I correct my code. It works.
  if (true) {
    const char *renames[] = {"Inlet", "Injection_2","haut",NULL};
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.}};
  if (true) {
    const char *renames[] = {"Inlet", "Injection_2","haut",NULL,"bas", NULL};
                                        {0., 1., 0., 0.},
    cs_preprocessor_data_add_file("/home/DH07120S/2754/Etude_Hexa/19_aig_22/MESH/mesh_input/base",3,renames,transf_matrix);
  if (true) {
                                        {0., 1., 0., 0.},
  if (true) {
                                        {0., 1., 0., 0.},
  if (true) {
    const char *renames[] = {"Inlet", "Injection_2","bas", NULL};
                                        {0., 1., 0., 0.},
END_C_DECLS
You must also put 3 in the function cs_preprocessor_data_add_file when you remove 2 groups.
Thank you,
Damien
DH07120S
Post by DH07120S »
It's better with this one :
  if (true) {
    const char *renames[] = {"haut",NULL};
                                        {0., 1., 0., 0.},
                                        {0., 0., 1., 0.}};
    cs_preprocessor_data_add_file("/home/DH07120S/2754/Etude_Hexa/19_aig_22/MESH/mesh_input/base",1,renames,transf_matrix);
  if (true) {
    const char *renames[] = {"haut",NULL,"bas", NULL};
                                        {0., 1., 0., 0.},
  if (true) {
                                        {0., 1., 0., 0.},
  if (true) {
                                        {0., 1., 0., 0.},
  if (true) {
    const char *renames[] = {"bas", NULL};
                                        {0., 1., 0., 0.},
DH07120S
Post by DH07120S »
Since the beginning, I only compute a preprocessor.
But when I run the calculation, CS puts a problem in my boudary conditions. Indeed, it creates a a groupe "no-group" where I remove my groups. I can't put nothing in this group "no-group" becoause it's a continuity condition.
How can I do ?
Damien
When you append meshes, boundaries remain boundaries, and there is absolutely no reason to believe that changing or removing a group's name will change that.
To transform boundary faces into volume faces, you need to use mesh joining (or periodicity, which is an extension of this).
