results output at nodes
jancici
Post by jancici »
HI
I am using code saturne cca 1 week.
Using salome for creating geometry and mesh.
I am familiar with paraview, so I wand to use it for postprecessing.
I did setup easy case, "flow in box". My fluid is glass.
How to setup or is it possible to save results data at nodes? I have saved results at cell level.
I would like to have results at nodes level for better postprocessing.
jancici
Re: results output at nodes
Post by jancici »
I forgot to write:
I am using code saturne 2.3.1
Jacques Fontaine
Post by Jacques Fontaine »
Code_Saturne is based on collocated finite volume method, so the variables are computed at the cell centers.
With Paraview you can use the filter: "cells to nodes" to interpolate values at nodes.
JF
