Page 1 of 4
effortts calculation (F=PxS)
Posted: Mon Sep 03, 2012 12:02 pm
by stage75
I want to calculate and display (in post processing) the forces applied to a BC. The number of my BC is 201, so I modified the
USPROJ.F90 subroutine like this :
! compute the efforts applied on a face number 201
iutile = 0
if (iutile.eq.0) return
! If efforts have been calculated correctly:
if (ineedf.eq.1) then
do ii = 1, ndim
xfor(ii) = 0.d0
call getfbr('201', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
do ii = 1, ndim
xfor(ii) = xfor(ii) + iforbr(ii, ifac)
if (irangp.ge.0) then
call parrsm(ndim,xfor)
endif
endif
return
end subroutine
Is this right or not? Thanks
Re: effortts calculation (F=PxS)
Posted: Tue Sep 04, 2012 9:16 am
by stage75
No idea !!
Posted: Tue Sep 04, 2012 9:19 am
by JamesMcNaughton
The forces are displayed in the post-processing by default (efforts).
If you want to print them to a file or something then you can use usproj as you suggest though delete the lines:
iutile = 0
Or change the value of iutile...
Posted: Tue Sep 04, 2012 9:47 am
by stage75
HI James Thank's for your response,
When I Write this line
in USPROJ.F90 I get this error :
mm@cict.fr :SRC.1$ code_saturne compile
gfortran -I/serveur/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usproj.f90
/home/mmeziane/Documents/STUDY/CASE1/SRC.1/usproj.f90:341.31:
[b] xfor(ii) = xfor(ii) + iforbr(ii, ifac)
1
Error: PROCEDURE attribute conflicts with COMMON attribute in 'iforbr' at (1)[/b]
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/ussatc.f90
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usini1.f90
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usclim.f90
Is this right if I right just iforbr and not iforbr (ii, ifac),
Posted: Tue Sep 04, 2012 10:00 am
by stage75
In post processing I don't have the "efforts" !
I have juste in FIELDS :
-CFL
-FOURNIER NUMBER
-PRESSURE
-REL PRESSURE
-REL VELOCITY
-TOTAL PRESSURE
-TURB DISSIP
-TURB KINETIC ENEGY
-TURB VISCOSITY
-VELOCITY
Posted: Tue Sep 04, 2012 11:12 am
by JamesMcNaughton
You're using saturne 2.0 so you should use the usproj of that version.. check your previous post here
http://code-saturne.org/forum/viewtopic ... 6077#p6077 (use the line you commented out).
Posted: Tue Sep 04, 2012 1:07 pm
by stage75
I use this line ?
I didn't have the "efforts" on the post processing menu!
Posted: Tue Sep 04, 2012 3:06 pm
by JamesMcNaughton
Change this line:
xfor(ii) = xfor(ii) + forbr(ii, ifac)
To:
xfor(ii) = xfor(ii) + ra(iforbr + (ifac-1)*ndim + ii-1)
That should work as per the v2.0.1 example of usproj..
Cheers
Posted: Wed Sep 05, 2012 8:45 am
by stage75
Thanks James,
Maybe I was not clear, what I want is to calculate the force on a wall that will allow me to calculate the Moment, ie at the end I get a single value.
Posted: Wed Sep 05, 2012 1:13 pm
Following Jame's post, you should be able to loop on boundary faces to integrate the contribution of the force to the moment you are trying to compute.
