effortts calculation (F=PxS)
stage75
Post by stage75 »
I want to calculate and display (in post processing) the forces applied to a BC. The number of my BC is 201, so I modified the USPROJ.F90 subroutine like this :
! compute the efforts applied on a face number 201
iutile = 0
if (iutile.eq.0) return
! If efforts have been calculated correctly:
if (ineedf.eq.1) then
  do ii = 1, ndim
    xfor(ii) = 0.d0
  enddo
  call getfbr('201', nlelt, lstelt)
  do ilelt = 1, nlelt
    ifac = lstelt(ilelt)
    do ii = 1, ndim
xfor(ii) = xfor(ii) + iforbr(ii, ifac)
    enddo
  enddo
  if (irangp.ge.0) then
    call parrsm(ndim,xfor)
  endif
endif
return
end subroutine
Is this right or not? Thanks
stage75
Re: effortts calculation (F=PxS)
Post by stage75 »
No idea !! :?:
JamesMcNaughton
Post by JamesMcNaughton »
The forces are displayed in the post-processing by default (efforts).
If you want to print them to a file or something then you can use usproj as you suggest though delete the lines:
iutile = 0
Or change the value of iutile...
stage75
Post by stage75 »
HI James Thank's for your response,
When I Write this line
in USPROJ.F90 I get this error :
mm@cict.fr :SRC.1$ code_saturne compile
gfortran -I/serveur/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused  -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH  -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usproj.f90
/home/mmeziane/Documents/STUDY/CASE1/SRC.1/usproj.f90:341.31:
[b]   xfor(ii) = xfor(ii) + iforbr(ii, ifac)
                               1
Error: PROCEDURE attribute conflicts with COMMON attribute in 'iforbr' at (1)[/b]
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused  -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH  -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/ussatc.f90
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused  -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH  -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usini1.f90
gfortran -I/serveurVega/logiciels/saturne/cs-2.0/include -x f95-cpp-input -Wall -Wno-unused  -D_CS_LANG_FR -D_CS_FC_HAVE_FLUSH  -O -c /home/mmeziane/Documents/STUDY/CASE1/SRC.1/usclim.f90
Is this right if I right just iforbr and not iforbr (ii, ifac),
stage75
Post by stage75 »
In post processing I don't have the "efforts" !
I have juste in FIELDS :
-CFL
-FOURNIER NUMBER
-PRESSURE
-REL PRESSURE
-REL VELOCITY
-TOTAL PRESSURE
-TURB DISSIP
-TURB KINETIC ENEGY
-TURB VISCOSITY
-VELOCITY
JamesMcNaughton
You're using saturne 2.0 so you should use the usproj of that version.. check your previous post here http://code-saturne.org/forum/viewtopic ... 6077#p6077 (use the line you commented out).
stage75
Post by stage75 »
I use this line ?
(xfor(ii) = xfor(ii) + iforbr
I didn't have the "efforts" on the post processing menu!
JamesMcNaughton
Change this line:
xfor(ii) = xfor(ii) + forbr(ii, ifac)
To:
xfor(ii) = xfor(ii) + ra(iforbr + (ifac-1)*ndim + ii-1)
That should work as per the v2.0.1 example of usproj..
Cheers
stage75
Post by stage75 »
Thanks James,
Maybe I was not clear, what I want is to calculate the force on a wall that will allow me to calculate the Moment, ie at the end I get a single value. ;) :?
Following Jame's post, you should be able to loop on boundary faces to integrate the contribution of the force to the moment you are trying to compute.
