[SOLVED] Code Saturne 2.3.1: issues /gradient calculation
Posted: Fri Aug 03, 2012 1:31 am
by laurent
Hi
Following the installation of Code Saturne 2.3.1, i re-ran a test that used to run well on Saturne 2.0.4
I may have found 1 issue:
-> everything runs fine when using "iterative handling of non-orthogonalities" for the gradient calculation method (albeit a message reading "run_solver.sh[10]: module: not found [No such file or directory]") but the calculation can not run when using all the methods with "least squares method"
I have this message in the listing:
"/tmp/saturne-2.3.1/installer/code_saturne-2.3.1/src/mesh/cs_mesh_quantities.c:1663: Fatal error.
The option selection indicator for the cocg computation
for vector gradients can take the following values:
0: do not compute cocg dimensionless matrices
1: compute cocg matrices
and not 0."
I am attaching the listing of a calculation that runs OK (***-1312) and calculations that doesn't run (***-1401)
Have a nice day
Re: Code Saturne 2.3.1: small issues with gradient calculati
Posted: Fri Aug 03, 2012 8:58 am
by Jacques Fontaine
I attached a fix, you can recompile Code_Saturne with it or add this files onto your SRC folder.
Could you tell me if the fix works on your test case?
Thanks for the feedback.
Posted: Fri Aug 03, 2012 10:18 am
by laurent
Hi
I tried the fix, it didn't seem to work BUT i was a bit in a hurry so i would prefer to take sometime to do things properly before saying it doesn't work.
Could have a closer look in about 1week and sadly i have another question/issue? on other topic
Sorry for the bad news on a friday!
Posted: Fri Aug 03, 2012 3:12 pm
by Jacques Fontaine
By the way could you attach your case here?
ty
Posted: Mon Aug 06, 2012 2:03 am
by laurent
Yes, but next week as i am currently away from the office.
Have a nice day and thanks for the follow-up
Posted: Mon Aug 13, 2012 1:52 am
by laurent
Hi
Here is the case discussed above
Posted: Mon Oct 15, 2012 10:08 am
by laurent
Hi
I tried my case again with Code Saturne 2.3.2 and there are no issues anymore with the "least square gradient".
There is still a warning with /_6/run_solver.sh but it doesn't stop the calculation
(_6 being apparently the new folder where Saturne 2.3 stores the post-pro results instead of date-time: is it normal?)
Have a nice day
Posted: Wed Oct 17, 2012 10:28 am
Good to know the issue has dissapeared.
But the case directory should be date_time, and not _6 (unless you changed the default behavior in the runcase by adding "--id _6" to the "code_saturne run" command).
Do you always have this behavior ?
