I'm quite new to Saturne and Syrthes and tried to run a coupled case after running both solid and fluid calculations.
The begining of the coupled calculation went OK but after the first time step it stopped as if it was the normal ending (" Saving calculation results").
After looking at the log files i think this comes from syrthes (log attached to this post) but cannot explain why.
Thanks,
Pierre-Nicolas
calculation stop / syrthes 4.0 & saturne 2.2 coupling
PNMauger
- syrthes.log
- (7.51 KiB) Downloaded 242 times
PNMauger
Re: calculation stop / syrthes 4.0 & saturne 2.2 coupling
I thought my problem was linked to mpi since it seems that the calculation failed to pass informations between the two codes (stop after one iteration), so i reinstalled syrthes using the option "mpi USE=yes INSTALL=yes" instead of "mpi USE=yes PATH=/usr" and it works well now.
Hope this could help others facing the same issue.
Pierre-Nicolas
Pierre-Nicolas
