I had used the automatic installation to install the following modules (MPI, BFT, FVM, MEI, ECS, NCS).
Can you give me more informations about next step.
I had this message.
Regards.
Rezki.
Installation of Code_Saturne
____________________________
The process will take several minutes.
You can have a look at the log file meanwhile.
Check the setup file and some utilities presence.
Installation of MPI
Installation of BFT
Installation of FVM
Installation of MEI
Installation of ECS
Installation of NCS
Before using Code_Saturne, please update your path with:
cspath=/home/chebli/opt/cs-2.0-beta2/bin
export PATH=$cspath:$PATH
The documentation should then be available through the commands:
code_saturne info -g refcard
code_saturne info -g user
Thank you for choosing Code_Saturne!
MANUAL INSTALL
Re: MANUAL INSTALL
Hi
You have to copy this in your ./profile file (have your file browser display the hidden files) so that you have access to the Code Saturne programs without typing the full path
basically typing "code_saturne" instead of "./where-is-code-saturne/bin/code_saturne"
Re: MANUAL INSTALL
I copied that in the ./profile file (that is attached)
I had this message
chebli@chebli:~/Bureau/Saturne/bft-1.1.2$ ls
aclocal.m4 bft_config_priv.h.in ChangeLog configure COPYING INSTALL Makefile.in README src
AUTHORS bft-x.y.z.build config configure.ac doc Makefile.am NEWS sbin tests
chebli@chebli:~/Bureau/Saturne/bft-1.1.2$ code_saturne
Usage: /home/chebli/opt/cs-2.0-beta2/bin/code_saturne <topic>
Topics:
help
check_consistency
check_mesh
compile
config
create
gui
info
plot_probes
Options:
-h, --help show this help message and exit
I had this message
Topics:
help
check_consistency
check_mesh
compile
config
create
gui
info
plot_probes
Options:
- profile.gz
- (447 Bytes) Downloaded 645 times
Re: MANUAL INSTALL
Code_Saturne seems to be well installed ;)
The next step for you Chebli is to use it !
The best way to do that is to follow the tutorial: this document is in
/home/chebli/opt/cs-2.0-beta2/share/doc/ncs/tutorial.pdf
and the associated meshes are in Code_Saturne's sources in the "examples" directory.
Re: MANUAL INSTALL
Thank you for your help.
But the /doc file (home/chebli/opt/cs-2.0-beta2/share/doc) doesn't contain the ncs file.
Thus I don't find the tutorial file and the associated meshes.
Regards.
Rezki
Regards.
Rezki
