Hi friends,
I installed two versions (2.0.2 & 2.1.4), when ever i gave the command as "code_saturne gui" ,its always opening 2.0.2 itself, I want to work on 2.1.4 but its not opening . why??
can you please help me out of this ??
Thank you.
theja
INSTALLATION OF MULTIPLE VERSIONS
Torben Andersen
Re: INSTALLATION OF MULTIPLE VERSIONS
My guess is that in your command search path you have the directory where you installed version 2.0.2. The output from running "echo $PATH" and "echo $LD_LIBRARY_PATH" may tell you what is wrong.
