Page 4 of 6
Re: How to calculate scalar based on frozen average velocity?
Posted: Mon Aug 30, 2021 9:55 am
by Tsubasa
What do you mean "this" in the following tips?
You can try this (in cs_user_time_moments) , but as I was explaining, since the cell velocity and ts time moment are not stored in the same restart file, this might not work (the best solution is to try and check).
Does "this" mean the following code?
  const int kr = cs_field_key_id_try("restart_name");
  cs_field_t *vel = cs_field_by_name("velocity");
  cs_field_set_key_str(vel, kr, "ave_vel");
Sorry this is a tribial question.
Tsubasa
Posted: Mon Aug 30, 2021 12:45 pm
Yes, it was the code I was referring to.
Posted: Mon Aug 30, 2021 9:11 pm
by Tsubasa
As far as I understand from a previous your post, by adding the following code in "cs_user_initialization.c", instantaneou velocity field is replaced with mean velocity field, isn't it? So scalar transport can be calculated in average field, can't it? And by the same manner, other instantaneous fields can be replaced with average fields, correct?
void
cs_user_initialization(cs_domain_t     *domain)
  cs_field_t *vel_m = cs_field_by_name("velocity");
  for (cs_lnum_t i = 0; i < cs_glob_mesh->n_cells; i++) {
  vel->val[i] = vel_m->val[i];
I did it for velocity field at a first test (I did not apply to other fields now), but it seemes that scalar transport was calculated in instataneous velocity field.
Would you give me tips?
Tsubasa
Posted: Tue Aug 31, 2021 3:46 pm
You code is almost correct (I did not check whether the error is in the example I gave or in your adaptation).
In you piece of code, for vel_m, the name of the field you access should not be "velocity" (the instantaneous value), but the mean velocity field (whose name may depend on your setup, but which you can easily search for in a previous run's "setup.log" file.
After that, you'll need to do the same for mass fluxes, but doing one step at a time is safe.
Posted: Tue Aug 31, 2021 4:59 pm
by Tsubasa
To activate the code correctly, I changed the name of vel_m to "meanVel" which I set up in GUI. These are the code and "setup.log" of a previous computation.
void
  cs_field_t *vel_m = cs_field_by_name("meanVel");
  Field                    Dim. Location             Id   Type flag
  meanVel                  3    cells                15   48   (postprocess, accumulator)
  meanPre                  1    cells                16   48   (postprocess, accumulator)
  inner_mass_flux_mean     1    interior_faces       20   48   (postprocess, accumulator)
  boundary_mass_flux_mean  1    boundary_faces       21   48   (postprocess, accumulator)
These code can be carried out without errors when computing.
However, in visualization by Paraview, something strange happend.
When I checked the instantaneous velocity field (this is should be "meanVel" field of the previsou computation), the field seems to a field mixed with instantanesou and mean velocity filed. You can see this in following pictures. First and second pictures are instantanesou and mean velocity field at last time step in the previous computation. Third picture is a "instantaneous" field which should be meanVel field.
For some meshs, meanVel field is taken into account, but instantanesou field also can be seen.
Are there some mistakes?
Tsubasa
Posted: Wed Sep 01, 2021 12:38 am
If you are running in parallel, just as a precaution, you can replace "n_cells" with 'n_cells_with_ghosts' in the loop where you copy mean to instantaneous velocity. just to make sure ghost cells are handled immediately an side effects are avoided.
If this is not enough, could you post the run_solver.log file for 10 or 20 restarted iterations ?
Also, the instant/mean mass flux may have an impact. So first, can you do the same operation (copy) of mean to instantaneous values for the mass fluxes ?
Posted: Wed Sep 01, 2021 9:30 am
by Tsubasa
I changed the name to "n_cells_with_ghosts",
but same problem can be seen.
You can see the log file.
run_solver.log
(129.49 KiB) Downloaded 1480 times
_________________________________________________________________
For mass flux. is the code correct below?
I am not sure how it should be wrriten for " inner_mass_flux->val = inner_mass_flux_m->val" and "inner_mass_flux_m".
void
  cs_field_t *inner_mass_flux = cs_field_by_name("inner_mass_flux");
  cs_field_t *inner_mass_flux_m = cs_field_by_name("inner_mass_flux_mean");
  cs_field_t *boundary_mass_flux = cs_field_by_name("boundary_mass_flux");
  cs_field_t *boundary_mass_flux_m = cs_field_by_name("boundary_mass_flux_mean");
  for (cs_lnum_t i = 0; i < cs_glob_mesh->n_cells_with_ghosts; i++) {
  inner_mass_flux->val[i] = inner_mass_flux_m->val[i];
  boundary_mass_flux->val[i] = boundary_mass_flux_m->val[i];
Would you check this?
At least now, some error message can be seen by this code.
_______________________________________________________________________
Whwn I use the following code to check where the code works or not, it seems that part of instantaneous velocity field was replaced with new value (in this case:1e5). You can see the result in picture. Blue zone cannot be replaced by mean velocity.
In my case, computation was done with 4 parallelization. I checked how it works without parallelization, and same problem happend. So problem is not due to parallelization.
void
  vel->val[i] = 1e5;
Hamada
Posted: Thu Sep 02, 2021 10:07 am
This is quite strange. Would you have a small version of the test case (including mesh and restart files) I could check this on ?
Posted: Thu Sep 02, 2021 11:42 am
by Tsubasa
You can download the directry below.
Becasue the file size is large if I include mesh and restarting file, I upload separately mesh, "before restarting file" and "after restarting file". You can get the result by just using setup.xml which I already set up.
https://filesender.renater.fr/?s=downlo ... b79116fd82
If you need other files, please let me know.
Tsubasa
Posted: Sun Sep 05, 2021 1:26 pm
I downloaded the files, and did not run the case yet, but looking at them, I probably have a simple explanation:
Since velocity is a vector field, you need to copy 3 values per cell, no just one. So you are only copying the first 1/3 of values.
The following version should work better:
void
  cs_lnum_t n_vals = cs_glob_mesh->n_cells * ve->dim;  // n_cells * 3 for vector field
  for (cs_lnum_t i = 0; i < n_vals; i++) {
    vel->val[i] = 1e5;
