Schmidt number in code saturne
Tsubasa
Re: Schmidt number in code saturne
Post by Tsubasa »
Sorry, I did not understand well about it.
I checked Doxygen and now I understood how to access a field,
and now I can find different behaviors by each schmidt number.
I would like to show the code for someone who want to do same thing.
void
cs_user_parameters(cs_domain_t   *domain)
  cs_field_t *sch_scal1 = cs_field_by_name("scalar1");  //scalar1 is name of scalar which can be seen in GUI
  cs_field_set_key_double(sch_scal1, cs_field_key_id("turbulent_schmidt"), 0.1);  //0.1 is schmidt number which you can change
in cs_user_parameters.c
Tsubasa
Tsubasa
Post by Tsubasa »
I compared two pollutant simulations; one with Sch(schmidt number)=0.7 and the other with default Sch.
So far I thought default Sch in codesaturne is 0.7 according to src/cogz/coini.f90 following
CODE: SELECT ALL
! ---- Schmidt ou Prandtl turbulent
  turb_schmidt = 0.7d0
  call field_set_key_double(ivarfl(isca(jj)), ksigmas, turb_schmidt)
Bbut is it wrong? Two simulations shows completely different results, and I found that default Sch is 1.0 according to my simulation results. Would you tell me this?
Hamada
The actual default is in src/base/cs_parameters.c, here :
 cs_field_define_key_double("turbulent_schmidt",
                             1., CS_FIELD_VARIABLE); /* sigmas(iscal) */
The code in coini1 changes this a a specific model (gas combustion, fire modeling).
So this seems consistent with your observations. Note also that in case of doublt, you can check the keyword value setings for each field in the "setup.log" file.
