Page 3 of 4
Re: effortts calculation (F=PxS)
Posted: Fri Sep 07, 2012 4:18 pm
by JamesMcNaughton
To calculate moment you need the cross product of the force vector and distance vector. Distance vector (assuming you rotate about origin) is stored in cdgfbo array. Just search for it in usproj it is explained well. From this you can calculate the moment at each individual face and then sum the moments as you do now with forces to get the complete moment.
Posted: Mon Sep 10, 2012 11:20 am
by stage75
THanks James,
I have a question concerning the number the tourns of the turbine,
Normally if I want that the turbine make 5 tourns/seconde I put in the subroutine usini1
omegay = 5.d0
but I obtiened a great velocity!
Do you have an idea about the number need to "omegay" to obtiened a correct velocity
Posted: Mon Sep 10, 2012 12:50 pm
by JamesMcNaughton
Hi - I think you've asked this one before (in any case I have answered it) so try using the forum search feature.
Posted: Mon Sep 10, 2012 1:36 pm
by stage75
Hi James ,
I find your explanation for "omegay" :
http://code-saturne.org/forum/viewtopic ... a&start=50
So, according to your explanation, if I put "omegay=2*pi" -ie. the turbine make 1 tourn /s
and in my case I want that turbine make 5 tourns/seconde, so I put "omegay = 2*pi*5.d0" in results I get a high velocity that's no correct, normaly with (5 tourns/seconde) I need to get a velocity maximum equal to about 1.5 m/s !! but me I obtiened Umax = 58.6 that's not correct!
Posted: Mon Sep 10, 2012 1:59 pm
by JamesMcNaughton
What is the radius of your turbine blade?
What is your inflow velocity?
Posted: Mon Sep 10, 2012 2:11 pm
by stage75
THe radius of the turbine in this case is 4.75 cm
I don't impose the velocity in the inlet since I'm running the fluid through the turbine
Posted: Mon Sep 10, 2012 2:21 pm
by stage75
if I use this relation "omega = u/radius = 1.5 / 0.0475) I obteined omega = 31 per seconde -ie = 2*pi*5 (that's correct) so if I put in USINI1 "omegay= 31.d0 I obtiened Umax = 58
Posted: Mon Sep 10, 2012 3:46 pm
by JamesMcNaughton
So looks like you are defining omegay correctly.
It is probably another problem.. does the listing reveal anything?
Posted: Mon Sep 10, 2012 4:01 pm
by stage75
No, the listing reveal nothing
here is the listing, normaly no prob
Posted: Mon Sep 10, 2012 4:41 pm
by JamesMcNaughton
You have only performed 10 iterations so you should perform more.
And if you are using 5 revs per second then you need to decrease the time-step. But it's hard to know since this listing doesn't correspond to your questions (omegay=0.5 here, and the domain is massive compared to your radius of 0.0475m).
Is this the correct listing?
