Page 2 of 2
Re: Tube heat enchange
Posted: Wed Sep 28, 2022 7:57 pm
by Luciano Garelli
As Yvan mentioned, you can change the time step factor (cdtvar) for the temperature to have similar characteristics times to reach a steady solution in case it exists.
In the following figure, you can see the difference in the temperature field for the same simulation time, while the velocity is the same.
Posted: Thu Sep 29, 2022 9:06 am
by jacob
Hello, could you share the example with the mesh and everything?
Posted: Mon Oct 03, 2022 3:48 am
by Luciano Garelli
To have rough wall option, you have to set a turbulence model and also a wall function, for default no wall function is used, soy the rough wall option is in gray.
jacob wrote: Fri Sep 23, 2022 5:11 pm
But I have no option rough wall even if I tick turbulence.
Attached is the case (The mesh correspond to the first post and should be improved).
run_solver.log
(605.48 KiB) Downloaded 1737 times
setup.xml
(13.06 KiB) Downloaded 1737 times
TuboM2.med
(1.79 MiB) Downloaded 1718 times
